The Shipyard ( Dry Dock ): Builds & Questions => Yachts and Sail R&D: => Topic started by: glenuk on July 23, 2009, 07:19:59 pm
hi chaps, i have cello tape glue on the hull of my tinto boat, what is the best thing to removoe it without damaging the hulll?
thanks in advance ..glen
p.s i think its fiberglass/gel
White spirit should be okay,depends on paint though.
White spirit will be ok as craftsod has said depends on the paint, try it where it will not be seen if it all goes wrong
WD40 or RP7 spray dewatering fluid will remove the tape & residue without damaging any other surfaces......... :-)) {-) Derek
Meths will do the trick removed hundreds of sticky things from typewriters,word processors, computers in my days.
Don't rub too hard.
3M do an Adhesive Remover spray as well. If the tape has been on the hull for a long time, donot be surprised if there is a little difference in the paint under the tape, compared to the paint around it.
if all else fails try liquid lighter fuel, its often used in graphics studios and stuff to clean and remove residues on drawing equipment, drawing boards, rulers and stuff, it evapourates and leaves no oily mess
Hi all, thanks for the feedback, used meths and now 100% ok,
What a wast of meth's --- why I can remember we used to use a loaf of bread and-----opp's!!! sorry babbling again.
Freebooter
glenuk glad it work 4 u has done for years 4 me
Nail Varnish remover works for removing sticky stuff too but check the substrate for suitability!
