Model Boat Mayhem - Forum
Technical, Techniques, Hints, and Tips => BRUSHLESS Motors and Speed Controllers => Topic started by: hover tim on July 31, 2009, 07:24:44 PM
Hi all i have got a Pelikam brushless motor its a ray C3542/06 to be preciese anway at the moment the the shaft is sticking thrught the normal end http://www.puffinmodels.com/category.php?dept=160 but i would like to move the shaft back so its sticking out of the back instead can this be done and if so how easy on a different note i am trying to find some lagre pusher prrops 4 blades but cant for the life of me find any ha anyone come across any
If its an outrunner, which it appears to be I don't think that you can reverse the shaft without major Eng works, if you look at the drive end there should be a small C clip that holds the shaft in. Did it come with a prop adaptor that bolts onto the rotating case, can this not be modified to drive what you want with the fixed part mounted in the boat.
Hope that helps
Monarch
can't help you with the motor , but for props try westbournes or cornwall models for off the shelf ones up to 150mm and M5 ,i think.
if they aint big enough then give prop shop a call.
daz
Remove the circlip on the fixed end, loosen the grubscrew on the rotating end that secures it to the shaft, push shaft through, tighten grubscrew. if second groove on shaft at end, replace circlip.
thats it
Nick
there is another washer like clip on the motor shaft thats underneth the circlip i asume that theat need to come out as thanks for the prop shop link should of said its a large 4 blade pusher props for a hovercraft using aircraft props
Hovertim
you may be interested in my solution re driving props from a brushless motor and four blade props. - see attached photos.
The shafts are tubes soldered onto the output shaft from the motor. Supported through Tamiya ball races they drive two normal props fixed in tandem . They dont have to be special pusher props - just use normal props with the driving side facing rearwards ( make sure they are rotating the correct way)
It works - believe me !!
Don B.
nice idea but i would need someone to make me a custom prop adapter as the one i have on at the moment is not long enough and i dont fancy splicing props
After a chat at the locl pond today i have manged to removed the shaft by tapping out using a nail punch then i put a flat on the shaft and put it back the way i want and all seems fine i can now use the vario props i had on before thats for the help
Tim
Sweeet... :-))
Nick
