The Shipyard ( Dry Dock ): Builds & Questions => Pleasure boats, Sports, Race, Power and Leisure Boats: => Topic started by: 6705russell on August 13, 2009, 10:00:52 am
Hi all,
Just at the stage now of propulsion for a fast launch and was thinking of using two Graupner outboards, has anyone used these and if so any info on them would be greatly appreciated, i was thinking of two of these....
http://www.cornwallmodelboats.co.uk/acatalog/graupner_2337.html
Russ
A bloke at our club has one with a brushless in it on the back of a 25 odd inch tunnel hull. Moves rather quickly ;)
I have a couple of the earlier GTX-500 outboards, and mine have shaft drive and bevel gears in the lower unit too. I was under the impression that the newer ones had bendy cable drive, but your link says otherwise.
The GTX-500s are pretty powerful, by my standards anwyay, and with a BB 850 motor in the back the ones you mention just have to be fliers! I'm pretty impressed with Graupner engineering, very little has gone wrong with mine, just needs a little grease and brush lube on the motot.
There,s 2 x outboards on ebay at the mo,item number 170389106438
Wullie
Any new news on this?
I am looking to do a small (around 25") twin outboard powered semi scale rescue/patrol boat but cannot find a suitable outboard anywhere. Aquacraft do one in the states that was fitted on a little boat in the ripmax catalogue but im not into spending a fortune so might have to can my plans.
Anyone got anything laying about or know of anything outboard 2nd hand etc?
Thanks.
Hi Guy,
I have these 2 I got with a boat, I have never run them but they work when connected to a battery. The motor has 'MRA' then 'Wizard' written on them. One has a bad cover, a screw has broken the case (see pic) and there is a split in the case that looks like it has been glued.
Anyway they are yours for £20 plus postage if you want them, if not I will put them in the for sale section.
Nige
Nige,
OOO yes please. I will send you a PM
Nige,
Got them thanks, i have sent a PM about payment but not sure if they are sending.
I've just bought a groupner GTX 650 with a 600 race motor. I found it realy easy to mount & set up. I'm going to put a water cooling jacket on it cuz it got a bit warm after 10 mins of full blast. over all it works realy well.
(http://i908.photobucket.com/albums/ac288/taximark/DSC00484.jpg)
