Mess Deck: General Section => Tugs and Towing => Topic started by: das boot on August 29, 2009, 10:34:00 am
Guys, attached are a few pics of the push tug hull I bought from ebay. You'll notice it's not exactly straight along the hull sides (I did get a partial refund on the cost because of this)...so, any ideas as to the best way to straighten it out?
(http://img269.imageshack.us/img269/2946/98325293.jpg) (http://www.postimage.org/)
(http://img198.imageshack.us/img198/9733/66383633.jpg) (http://www.postimage.org/)
(http://img269.imageshack.us/img269/8049/17895090.jpg) (http://www.postimage.org/)
Sorry about the poor quality pics, camera batteries need a charge.
Ta
Hi Rich
You could try clamping the sides together with sturdy timber lengths and then apply a 'Hot air gun' gently. Let it cool and then do it again. Leave the clamps on for a day and it might solve your problem.
Hope this helps
Ken
Easy answer, frame it out inside.
I hope this helps?
Paul... ok2
That's what I did consider Paul, frame it on the inside with 1/4" x 1/4" hardwood, clamping everything up and keeping my fingers crossed that it straightened itself out.
Ken, don't have a hot air gun, but I have the good woman's hairdryer on standy. She'll not know I used it, she's in Canada....
Thanks chaps...
Strap wood to either side and fill with boiling water, then let it cool to avoid distortions - then frame it.
Make sure the deck you fit is striaght and wedge it in.
Only for slight bends, I have seen a model tear itself appart because to much force was stored up. when ir went it took modt of the deck of :o
hmm...some interesting replies there, thanks guys.
The problem has sort of solved itself...the chap who moulded the hull is a member of Mayhem, he read this and is in the process of moulding another one for me, hopefully with straighter edges this time!
Thanks for the input chaps....watch this space!!!
i will start the bidding at 50p for the old hull lol........see how this bidding goes!
50p bid.......!
£10 plus p&p....take it away.
if the sides have bowed in a little it might just be that the resin had a little too much catalyst put in it causing it to shrink a little whilst curing.Nothing much to worry about but as you've got a new one on it's way i'd vote for framing it inside as well.I'm going to try and post some pics of a 24" Damen style harbour tug i've done the plug for on here tonght and see what the mayhemers think!
Good luck with the build.
cheers
stevext
Cut a 1/2" Ply deck, making it a tight fit and tap it in, then apply epoxy to seal around the inside.
Thats what I did for my Springers.
Len.
