The Shipyard ( Dry Dock ): Builds & Questions => Springer Tugs => Topic started by: jabba on September 22, 2009, 09:15:52 am
hi guys
need to know if this motor and gearbox will fit and which prop i use,
mfa 5 pole 980D61 (4.5v - 15v) WITH RE 385 MOTOR. RATIO 6:1
i think its around 2000 rpm at 12v.
http://www.mfacomodrills.com/gearboxes/980d_series.html
if this don't work what will ?
thanks for your help and love the site.
No need for a gearbox,540 motor with 50mm prop on 6v,is fine
and it doesent get hot? must have no pitch on it I would have thought I would have thought 35mm was more like it.
Peter
It does get hot thats why i got water cooling in them
Mark
The best speed is around 6000 rpm for the standard 1 1/2" 40mm prop in a Springer, this will give you excellent power without overdoing it, if your building a more scale like vessel then 4000 rpm might be more appropriate. If your using a larger prop then reduce the speed, the motor you have mentioned is too slow unless the boat has a 4" 100 mm prop.
Nick
thanks for info guys,will get a motor around 6000rpm.
