Technical, Techniques, Hints, and Tips => Other Technical Questions... => Topic started by: Edmund on September 26, 2009, 12:16:09 am
Hello :-)
Does anyone know a supplier please of a 16" M4 prop shaft with a tube diameter of 6mm rather than 8mm? :((
ta, Ed.
shg do a sports shaft with Glacier bearings if you ring them I am shore they will make some that size, Glacier are much better than standard aceteal
Peter
SCOONIE HOBBIES use to carry a stock of slimline shafts may be worth a try www.scoonie-hobbies.co.uk Regards Andy
:-)) Found some same place I got me A frames from :}
http://www.gsitek-props.co.uk/
:(( then again mebbe not, they are 8mm on the plan after all {-)
