Mess Deck: General Section => Chit-Chat => Topic started by: Bugsy on September 28, 2009, 07:26:06 am
Title: Well, I never knew that ...............
Post by: Bugsy on September 28, 2009, 07:26:06 am
Needed a tiny bit of paint to touch up a spot on my hull and the aerosol can was empty.
Cut the can open (I know it says you shouldn't  ;) ) but my need was great and I did empty the gas first.
What was inside ................... not ONE but FOUR steel balls  :}
You learn something every day .
Title: Re: Well, I never knew that ...............
Post by: Wasyl on September 28, 2009, 07:19:54 pm
The paint does,nt mix itself,hence the little steel balls,
Wullie
Post by: Bugsy on September 28, 2009, 07:26:19 pm
Yes but, how many people thought there was only one?  :-)
Post by: dougal99 on September 28, 2009, 07:28:43 pm
Never mind how many there are, what are you going to use them for?  {:-{
Post by: Colin Bishop on September 28, 2009, 07:38:41 pm
Spares?  %)
Post by: J.beazley on September 28, 2009, 07:51:03 pm
Ballast  :-)) O0
Post by: Bee on September 29, 2009, 12:51:06 am
I think that IS truely amazing these days, unless it was a very old can. What can be done by 4 balls can be dne by 3 and the customer wouln't know the difference and so on. So in the company I work for it would be down to one, and the size of that would be shrinking.
Post by: dodgy geezer on September 29, 2009, 12:55:30 am
I suspect you will find that, somewhere on the Asian continent, there is a paint factory where the balls are put in manually, and they pay the workers per ball.....
Post by: Bugsy on September 29, 2009, 06:04:13 am
Well, I've nearly got enough to make one of these
http://hyperphysics.phy-astr.gsu.edu/hbase/balls.html
If I can work out a way of drilling a hole in them  :-))
Post by: Wasyl on September 29, 2009, 02:56:29 pm
Great ammunition for a Catapult, {-)
Wullie,
Post by: das boot on September 29, 2009, 06:08:07 pm
Sounds like a load of old spherical objects to me...
Post by: Tug-Kenny RIP on October 04, 2009, 02:04:06 pm
Did you find any paint in the tin?  Does it ALL extract with the gas ?
Post by: dodgy geezer on October 04, 2009, 09:26:08 pm
I opened a couple of Halfords spray tins recently to save buying another. Depending on where the tube has ended up, you may get anything up to about 1/2 cu in of paint out. But of course the paint will be very thinned - so brushing with it will tend to wash away earlier paint. You can leave it to thicken, of course, or put it in an airbrush...
Post by: Bugsy on October 05, 2009, 10:26:11 am
Yes, quite a bit actually. The pick-up pipe is central so the paint lies around the inverted dome at the bottom. I've put it in an old 'pill' bottle and so far, its remained liquid.
Post by: Tug-Kenny RIP on October 05, 2009, 10:35:12 am
                       Well I never knew that
