The Shipyard ( Dry Dock ): Builds & Questions => Navy - Military - Battleships: => Topic started by: rsm on December 06, 2009, 08:02:47 pm
Title: USS Chevalier
Post by: rsm on December 06, 2009, 08:02:47 pm
Thought I would share some pictures of my latest build based on the Revell 1/144 Fletcher kit. I've converted it to 2 channel using en Electronize speed controller, two 280 motors and Hitec radio gear. I built it as standard except for the addition of some turned brass main gun barrels.
Cheers.
Title: Re: USS Chevalier
Post by: Mark47 on December 07, 2009, 10:53:57 am
I'm not familure with this class of ship.
So can I ask, what are her dimenssions at this scale?
Post by: rsm on December 07, 2009, 01:57:18 pm
A Fletcher class destroyer at 1/144th scale is 79.7cm in length with an 8.3cm beam.
Post by: Mark47 on December 07, 2009, 03:40:03 pm
Thanks for the answer. :-))
Post by: farrow on December 17, 2009, 09:56:36 am
I am currently putting one of these kits together and I am interested in how you R/C it. How about some pics to see how you did it. Your model is nicely finished and it does show how the Yanks where well ahead of the UK in destroyer design.
Post by: rsm on December 19, 2009, 07:26:08 pm
The prop tubes are brass tube with short lengths of smaller diameter tube super glued into both ends as bearings. The propeller shafts are brass rod epoxied to the kit props. The prop shafts  are connected to the motors with silicon tubing. The rudder has a brass rod attached to it and passes through a piece of brass tube epoxied to the hull so it rotates.
Post by: Abuelo3 on April 21, 2010, 10:32:11 pm
IT IS A VERY GOOD LOOKING SHIP,  :-))SHARP AND RIGTH MADE, , BUT A I WANT TO KNOW ABOUT HOW IS SHE ON THE SEA, DID THE KIT'S PROPS WORKED, IF THOSE PLASTIC DONT BREAK. PLEASE TELL ME ABOUT IT
BEST WISHES
Post by: rsm on April 22, 2010, 02:12:51 pm
The kit propellers work just fine without any problems. She has a good turn of speed and handles quite well, but she gets thrown about a bit if the water is choppy.  %%
Post by: Jimmy James on April 23, 2010, 11:03:43 pm
I remamber seeing one of these Fletcher class Tin Can's going into the Naval Base at Charlestown South Carolina USA in the early 60's she'd been a bit roughly handled by the Old Grey Widow Maker and was looking very much the worse for wear "The side of the forward 5" 38 gun mount was bashed in,... the foredeck had been washed clean (no rails or storeage reels ) the after funnel had a bit of a kink in it and the motor whaler only had one side. But Pride of place on the bridge wing was a cartoon painting of Woody Woodpecker on a Surfboard .... The Caption Reading  40 KNOTS AND NO SMOKE + a string of Battle Ribbions.
Freebooter
Post by: farrow on April 26, 2010, 11:24:45 pm
Hi RSM.
Thanks for the reply, very impressive, I like the rudder detail.
Post by: Harquebus on August 19, 2012, 01:52:34 pm
The real ones got thrown around too.  ok2
Post by: Harquebus on August 19, 2012, 01:55:35 pm
Since the shafts turned out so well, scale wise, what diameter are they?
Here's one converted and running in calm water: http://www.youtube.com/watch?v=Mc5CTuyMQzk
