The Shipyard ( Dry Dock ): Builds & Questions => Seaport Tugs => Topic started by: marinemole on January 26, 2010, 02:26:22 pm
Have converted the Seaport Tug to a freelance steam outline based on a model steam powered tug I saw on the Net. Radio is now 2.4 GHz and motor control by a Viper ESC. Still work to be done, some details to be added and model to be painted. Still in rather patchy grey primer.
The outline looks a little top heavy but fairly pleased by slightly quirky appearance. Enormous ventilators are as a result of using ping pong balls cut in half. After a sinking in its original guise last year I have filled all available interior space with the rest of the pack.
(http://i669.photobucket.com/albums/vv59/carmanmole/Lomond%20Shores/DSCF5147crop.jpg)
(http://i669.photobucket.com/albums/vv59/carmanmole/Lomond%20Shores/DSCF5154.jpg)
(http://i669.photobucket.com/albums/vv59/carmanmole/Lomond%20Shores/DSCF5155crop.jpg)
(http://i669.photobucket.com/albums/vv59/carmanmole/Lomond%20Shores/DSCF5157.jpg)
Have sailed the model once at Lomond Shores, Balloch, Scotland with the preserved paddler Maid of the Loch as a backdrop.
http://www.youtube.com/watch?v=uL5hDAsj3is (http://www.youtube.com/watch?v=uL5hDAsj3is)
The model can be put back to something approaching its original state by simply switching superstrucures.
A nice quirky conversion Mole. I thought it was a vintage US Navy harbor tug because of they grey colour. I`d decided that was going to be the theme of my conversion but probably in WWII Russian grey livery , lend lease or something. I havent got too far along the route so far but here are a couple of pics.
Very nice models!!! I to am converting one of these tugs...............but i had a problem! I put in a new prop shaft and a 45m brass prop ( kept the original motor ) and proceeded to burn the motor out!!! Before running yours just check the motor has ' breathing slots ' . The plastic engine mount and the heatsink ( thin plate ) both need slots cutting out of them to give the motor ventilation. I now realise i was trying to spin too big a prop with the original motor. Could you please tell me the size of the original prop please ( i sold mine when i converted ) as i will replace my prop with the original size. Regards, Dave.
Thanks, there was an answer to the prop size on one of the threads here, I think it is titled "Prop Size" IMHO 45 mm is too big for the standard motor yes. I`ll be fitting a Springer set-up. 540 motor 35mm direct to see how it goes. Water cooling coil and open mount slots of course.
Like your conversion, be sure to keep updated.
The original is 45mm diameter plastic, perhaps something to do with weight and possibly pitch? . I have kept the Kort nozzle. Out of keeping with vintage of tug but the manoeuvrability it affords is too big a plus for me to ignore as we often sail in a fairly narrow waterway.
Andy
Dave I have just measured my prop which is original and it is a 40mm 3 blade.
Thanks for the info on prop size, i will probably change my brass 4 blade 45mm prop to a 3 blade 40mm plastic one as originally fitted. I suppose a brass one takes more power out of the motor and battery to turn or am i just being fussy? Regards, Dave.
Brass wold be OK as long as its 3 bladed and 40mm. :-))
Hi! thanks for that, i will go for a brass one, by the way do you use a 6v 4.5 amp battery or a 6v 5amp battery? Is it ok to run my receiver on the 6v SLA battery using the BEC or would you advise to run the receiver seperatley? Regards, Dave.
Hi Dave I run mine on a 6V 5amp SLA and a seperate supply [4AA batteries] for Rx.
You can use a 6V 4.5amp if you want.
You can run the Rx of the Bec if you like.
Sorry guys. just re-measured my prop, this time with my reading glasses on, and it is of course 40mm. <:(
Nice Tug DickyD, like that. O0
High! Just wondering how people run the receiver aerial. Do you have it running vertically outside the boat or horizontally around the inside of the hull?? Regards, Dave.
Either, it doesn't matter.
Cheers! thanks for that, i have,nt given up at getting my Dickie tug running once and for all!!!! Regards, Dave.
