Mess Deck: General Section => Chit-Chat => Topic started by: Aydemir on March 02, 2010, 03:42:11 am
Hello guys, there are some hand made mini swords made by jigsaw blades. Maybe you like them. Regards for all. Aydemir {-)
some more pic...
Very nice. I'm always amazed at the ideas people have for making things from unexpected materials.
Excellent workmanship!
Are they made just using files etc?
Hello Martin, I used to shape them with Dremel hand tool (New one) I have also Black&Decker hand rotary tool. I just mark over the jigsaw blade with marker. After
I used small cutting disk and I cut the desired shape. I try to not heat the steel and I
dipped in the water several time. After that I used several small grinding stone on the
rotary tool and shaped more. After basic shaping I used small diamond hand files for
smooth the surface then used several metal sand papers. Also I used some brass and
mahogany for hand part. Lots off sanding and polishing after just put some clear varnish
for the handle. I was try to make like real ones there are some pic I observe.Next one
maybe Japanese Katana. Regards
Hello pals there are two more mini swords unfinished and one mini dagger. One other
broken recycle pieces. Regard for all Aydemir.
Two mini swords finished....
Great work on the Katana, very realistic.
After Polished another two pictures.
