The Shipyard ( Dry Dock ): Builds & Questions => Working Vessels => Topic started by: kiwi96 on May 11, 2010, 11:22:54 am
Hi. Was wondering if any one here can point me in the right direction. Looking for plans so can build an ice breaker of the type in the links.
http://www.casr.ca/bg-icebreaker-svalbard.htm
http://www.marinetalk.com/articles-marine-companies/art/Norwegian-Coastguards-First-Icebreaker-DNV00955403IN.html
http://en.wikipedia.org/wiki/NoCGV_Svalbard
http://portal.fma.fi/sivu/www/baltice/jaanmurtajalista.pdf
Just that being her in NZ where it is a warmer climate, we do not see these vessels so I do not know where to start.
Any help appreciated.
Cheers,
Adrian.
IO have a set of plans for ice breaker "Norman Mcleod Rodger" from |Marine Modelling International plan no MAR3406 IF THATS ANY HELP!
I don't think this helps (and I'm very rarely helpful %) ) but Graupner used to make a Icebreaker kit called the Kontio.
(http://www.msh-modellbau.de/modelle/modellbilder/74_005_web.jpg)
http://www.msh-modellbau.de/index.php?sTemplate=ViewModellDetail&iRubrikID=8590&iAktModellID=74
Kontio kits are a bit of rare breed these days... Seems like there were two on the Wants and Swaps a month or
two ago... I did a bit of searching, and came up with the following image...
Can't be completely accurate, but it's a start...
Hi there,
Yes I'm the one looking for the Norwegian Icebreaker plans on behalf of my client. He has moved on from trying acquire a Konito as they seem to be totally unavailable now. Even 2nd had it's a tough ask. I guess if any of your Norwegian Coast Guard members are able to shed light I would be most appreciative. Cheers, Graeme
Hi Umi.
Any longitudiinal lines for this? Cheers, Graeme
Hi Umi.
Not yet, but if I, or someone, can come up with a profile for the ship, or it's sister/cousin ships, then
I can probably work out the general placement of those lines.... ok2
I wonder if anyone in these topic could help...
http://www.modelboatmayhem.co.uk/forum/index.php?topic=19053.msg228693#msg228693
http://www.modelboatmayhem.co.uk/forum/index.php?topic=1949.msg18853#msg18853
Here is a shot of the Norwegian Icebreaker that I'm looking for hull lines etc. etc. cheers, Graeme
Okay, Definitely not accurate, but the best overlay I can produce with the two pieces above.
The hull lines don't quite seem to account for the Ice breaking keels.
This is my best guess... ;)
I accounted for (4) frame #10 amidship.
That would be the most outside line on each side of the frame plans.
Umi.
Brilliant. Thank you. I will take all this and talk with a 3 D company. cheers, Graeme O0
