Technical, Techniques, Hints, and Tips => The "Black Arts!" ( Electrics & Electronics ) => Topic started by: Microyacht on May 16, 2010, 11:49:49 pm
Does anyone know of an electronic module that will produce sound like twin Air Horns. Built or kit of parts?
Many thanks
Steve/G4MJW
Golf four Mike Juliet Whiskey,
To answer your question with a question, do you want a straightforward twin air horn sounder unit, or would you be interested in a unit which stores and plays just about any sound that you so desire?
You'll like this one because you can download and playback an abundance of pre-recorded sounds from the Web... even your own recorded sounds......
http://www.action-electronics.co.uk/engines.php
Right at the top of the page -- P100 ("noisy thing")
Or there's this one
http://www.action-electronics.co.uk/pdfs/P57.pdf (http://www.action-electronics.co.uk/pdfs/P57.pdf)
Kit or built - take your pick. The clue is in the name 8)
FLJ
. . . . Many thanks both for the info with links. It's only Twin Air Horns I want, I think. I'm trying to think if there is anything else that would be interesting to include.
I'm building something a bit odd. I normally make sailing boats especially catamarans BUT this is a modern houseboat. It can be moved around by it's own power and the will be a mast, the top of which is similar to a typical power boat type with the cross-arm (bit like an aircraft tail)!
I'll probably go for the kit that uses a pair of NE555 timers and a small Amp chip (TDA7052).
I'll post some pictures of the boat shortly!
Good choice.
By the by, a slight bit of confusion with your signature G4MJW / M4GJW thingy.
PMK . . .
Weird, senior moment Mmmmmmaybe! lexdyslik ? Anyway fixed the signature. You'd think I'd know my own callsign by now!
I was talking to my brother (G8HSI) this morning on S13 and we thought of using a pair of 555's or a dual-555 and a TBA810 audio amp. Or a couple of 741's + an amp . . . . obviously stuck on a bit of Vero board or even a rat's-nest! I wonder if Action-Electronics have a .waw or MP3 file of the sound the unit makes. I've had Air-Horns on cars and boats, they have a unique sort of reverb/resonance that I hope that unit with it's 2 oscillators might produce. Well, 2 frequency pots, and no doubt can change the purity of the tones by changing/adding C's or R's! The boat will have taken about 6 weeks to build but I'll play for ever getting the twin horns tone right!
Steve
Check out the kit parts and layout on the link I placed. It does indeed use two 555 timers and a TDA7052 1.2W amp. You can vary each of the tones and make it sound as raucous as you like, including that resonance/strobe effect when the two frequencies are only a little bit apart. As the sound is so variable there's no definitive sample available.
FLJ
Sure, a 556 would do it. And you could use most any audio amp you want.
I can't help you any regarding ACTion's sound file for the air horn, only I'd guess that each 555 is pumping out a squarewave, and although producing a very good simulation, may otherwise sound a tad 'raspy'. In other words, try not to expect too much from the poor old 555s.
Build one first, see how you get on. You'll probably have a blast messing with different C/R values.
<edit>
Oops!... FLJ beat me to it.
Scrap what I'd said and just treat yourself to the P57 already?
Hi and thanks again both! LOL
I've already downloaded the the .pdf construction manual. If i'd been given a £ for every NE555 timer or 741 op-amp I've used over the years, I'd be living in the Caribbean on a 60ft Cat! I think it's exactly what I am looking for. I will probably get the kit of bits. I still have a component cupboard but get all the parts together is another thing. May have the 555's but not sure if I have any small audio power IC's.
. . . Oh, this is one other thing, I need to find a nice pair of shiny air-horns to go on the boat
