Mess Deck: General Section => Chit-Chat => Topic started by: zaskar on January 11, 2007, 03:36:01 pm
As mentioned in another thread, I would like to build a 1/4 scale model of a working narrow boat. I've taken lots of photo's and sketches to assist me in this, my first build, but what I'd really like is a copy of some plans for the bow section so that i can make the frames and get the lines right.
Does anyone know a source for this info please/
There are usually narrow boat plans on eBay - not 1/4 scale as far as I recall, but maybe they would help.
Barrie
"Shire Cruisers" at Sowerby Bridge just outside Halifax actually build thier own boats.
Drop them a line and see if they are able to help in any way.
http://www.shirecruisers.co.uk/
Someone has built a mini speed boat and there is a thread on here.
The angles are different but the basic construction technique may be suitable if you cahnge the angles.
There are lots of pics of the frame about one third down the page.
Just a thought.
http://www.modelboatmayhem.co.uk/forum/index.php?topic=312.0;topicseen
Many years ago I wrote to the British Waterways Board asking for plans for the new Eco-hull and they sent me some free. You get bow & stern, and the length of the middle is up to you. That's fine if you want an Eco-hull - but it should give you less wash and therefore drag, or vice versa, and the bow should be dead easy to do in ply. Incidentally, I think that propellor sizes for HPV boats are quite large - some year ago I saw a Dutch pedal-powered inflatable catamaran on the Basingstoke Canal with an outboard type submerged drive and the prop had large paddle blades and was about 10" at least in diaa. Think WW1 aircraft propellors - low revs, low power, plenty of torque - big wide blades. A smaller prop would probably need gearing up and you'd lose any extra propellor efficiency in the gears. I think. To keep weight down you could reduce freeboard - it might be worth your while looking at canal tug styles, or the BWB workboats which are more flat-iron style. But if your heart is set on roses and castles, go for it.
