The Shipyard ( Dry Dock ): Builds & Questions => Working Vessels => Topic started by: destroyer42 on June 16, 2010, 05:46:02 pm
Dear Colleagues,
A few pictures of my tow boat sister ship that I have just finished for a colleague of mine. Just needs to be painted.
Destroyer42
(http://s1.postimage.org/uh6Hi.jpg) (http://www.postimage.org/image.php?v=gxuh6Hi)
Nice Job! :-))
How did you do the window frames?
Hi Martin,
I use 3mm plastic 90 degree angle and mitre it. Realy easy to cut and stick with either cayno or plastic weld.
As you can see I have used differnt sizes throught the boat.
Hull is made from 5mm ply the bottom is made from 2mm ply due to having to bend it as there are a number of compound curves underneath , then glassed.
Superstructure is from 3mm plastic all other bits and fittings are either 2mm or 1mm plastic card.
Hi Colin,
very nice job! The pusher looks great.
Wilhelm
They look very nice,good job.
Jenno.
