Technical, Techniques, Hints, and Tips => The "Black Arts!" ( Electrics & Electronics ) => Topic started by: gwa84 on July 13, 2010, 12:04:11 pm
this has hpi Japan on the back and roar stock on the front it also has changeable bushes and screens its head off on 7.2v :}
(http://i275.photobucket.com/albums/jj298/wiplash84/100_0545.jpg)
(http://i275.photobucket.com/albums/jj298/wiplash84/100_0546.jpg)
(http://i275.photobucket.com/albums/jj298/wiplash84/100_0548.jpg)
(http://i275.photobucket.com/albums/jj298/wiplash84/100_0547.jpg)
gwa84
It is a car motor made to rev it's head of and use up to 35 amps, no good for a boat as it will only last for about five minutes..........
Roy
It has car motor brush gear, but isn't a slot car motor as they are never round.
Did you mean R/C car?
Vintagent
It could be somewhere between a 32T and a 27T motor,and will produce in the region of 16,000+ rpm @ 7.2V. If you ran it on 4.8V however,the revs would drop to around 11,000 rpm,which with a 25-30mm 3-blade prop will,if it's a balsa boat,give you run times in excess of an hour. That's what is in my Vosper corvette. :-))
David.
