Technical, Techniques, Hints, and Tips => Other Technical Questions... => Topic started by: Wasyl on October 01, 2010, 07:13:15 pm
Hi guys,would a Graupner 8ch receiver be compatible with a Futaba transmitter,the receiver is an FM 40mhz
Wullie
probably not, Graupner are mainly JR parts
Try it and see, I mix brands of equipment all the time and find they talk to one another just fine.
The problem with trying it, is the receiver is in Scotland and the transmitter is in Finland {:-{
Wullie
I see- you have a bit of a problem then!
I have Graupner and Futaba/Robbe Tx and they with both RX's. The RX need to be shift sensing and Futaba and Graupner use different shifts - but most RX are auto shfit these days.
ive in the past mixed radios , sometimes it works other time not , these days i stick to matching brands & crystals when required ! you may have a slight range issue from finland to scotland though !
Hi Wullie.
My Graupner and futaba stuff wont talk to each other. What I found is robbe, futaba, acoms, and hitec are compatible.
cheers Frank
Wullie
Reckon it won't work from here either, <:( <:( <:( sorry bout dat but keep tryin {-) {-)
Hi Wullie.
cheers Frank
I have to disagree... my robbe 2ch TX says by futaba on the front lol its basicly the attack and is used with both acoms and Futaba RX
My laser 6 TX is currently setup and talking to a 6ch futaba RX in my RC plane and the acoms 4ch rx in my King hauler
I think its a case of suck it and see.
Me and wullie have come to an agreement
Ill let people know the results
