The Shipyard ( Dry Dock ): Builds & Questions => Navy - Military - Battleships: => Topic started by: wallace on October 23, 2010, 10:59:51 am
Does anyone know if a kit or simi kit is out of HMS NURTON one of the ton class minesweepers heared its a big model and to the scale of 1.24 thanks wallace
Models by Design produce a hull.
There was a kit made but was only about 18 inches long.
the models by design hull is 1:38th scale (a strange scale)
but It is a great model for sailing with plenty of room inside yet a reasonable size for the car
you need to build all of the model as there are no fittings for it :-))
Hi! Wallace,
I have Copy drawings of HMS Nurton, but I must warn you she was a "Mine Hunter" not a Sweeper.
If you want them I can lend you them but as already stated you will have to make all the fittings and the boat from Scratch.
I am building HMS Maxton as you know. (NBMBC member) Bill
Nurton was a sweeper as all of the Ton Class were.
Some were converted to Hunters The sweep winch
and the pulse genny were taken off and the
diving equipment stores were fitted
Tiger Tails were fitted on the Bridge Roof
There is a 1:24 scale model in the market.
Probably made by Vipo Deck Co ltd.
If you want me to find out - just let me know.
Deans Marine do a 1/96 scale of Bronnington in her guise as minehunter - kit is 465mm long
Cost £107
Geoff
I have built HMS Kirkliston to 1/48 scale using a Sirmar Hull (sadly no longer available) and the Jacobin plans for HMS NUrton , i Had a lot of changes to make to build Kirkliston and used my own photos from when I served on her and internet research . Kirkliston was the first Ton to be converted to the minehunter role . The model looks great and performs well on the water .
(http://s4.postimage.org/1nlhr0bdw/DSCF0467_640x480.jpg) (http://postimage.org/image/1nlhr0bdw/)
Sirmar products have just become available again.
See http://www.sirmarfittings.com/
Peter
