Mess Deck: General Section => Chit-Chat => Topic started by: regiment on December 29, 2010, 03:26:20 pm
hello all is it possible to change a vodaphone pay as you go to orange pay as you go thanks
Sorry, no, Gordon.
Happy new year to you and Maggie. :-))
only if you have it unlocked from vodaphone, can you use any server
davidj
Any mobile phone shop will unlock it for you for about a tenner, or if it's a Nokia you can probably get an unlock code from the various internet sites. Some of the latest phones are difficult to unlock, but the good old basic Nokias are a piece of cake to do.
just had my daughters new Nokia 5800 misicxpress unlocked from Tmobile to take an ASDA card.....a tenner...no probs.
You can unlock certain phone from service providers, some you can some you can't.... eg. no one can unlock my Nokia 2700 >:-o
YES, although as others have said you will need to get the phone unlocked to use a different network. You can pay Vodafone to do it or search the net there are websites that will give you a unlock code for a small fee. You can also find some shops in local markets etc that will unlock it for you.
thanks for all of your answers will get it done after holidays
5lb lump hammer unlocks 'em NO problem.
Regards Ian
its also possible to take your phone number with you if you change service providers , but it can take around a week , ive had my mobile number for the last twelve years , i started with orange , its been to o2 then to vodaphone where ive been for the last four years ! some moblies will work with otheer companys sim cards in them , depends on where you bought the phone as to weather its locked to a particular network .
Duplicate topic by the same poster was removed,
Peter Fitness
Moderator
In the past I have had a Vodaphone phone that wouldn't accept my Orange SIM card, my current Orange phone accepts my wife's O2 SIM, all my past O2 phones accepted any SIM.
However, as has been said, an unlocked phone will accept any SIM- however take the SIM that you want to put in the phone along with you and try it in the shop, it isn't guarenteed.
Some phones, if you go to 'phone settings' then 'network settings' some have an option to select what network you want the SIM to work on.
After being with all uk mobile providers excepting 3mobile I have to say Orange is by far and away the best network to be with- fantastic signal, never had a 'network busy' pop-up while trying to call or text and they reward their loyal contract customers with 'haggling' deals on upgrades. Not to mention they now own/share T-Mobile's signal network- though T-Mobile's signal was so pitiful to start with I havn't noticed a huge difference, and of course you get 'Orange Wednesdays' 2 for 1 cinema tickets, I certainly won't be going with anyone else.
Greg
what model of Mobile phone is it? I can normaly track down the codes needed or instructions on how to sort it. This gives you an extra £10 for boat bits :-))
morning my lord the phone is a nokia no 1616 or 1800 thanks gordon
sorry about the delay in replying
you need to get your IMIE of your phone, type *#06# and press call, this should show it. then go to
http://www.unlockme.co.uk/master.php and type the number in that should give you the unlock code.
you could also try 12345 as Nokia has this as a standard unlock code.
This is the standard Nokia unlocking procedure
1 – Switch ON your phone without SIM Card,
2 – Compose #PW+CODE+1#
(if locked from Fido/Roger Canada, please compose#PW+CODE+7#)
The letter P appear after press 3 times quickly the button star ( * )
The letter W appear after press 4 times quickly the button star ( * )
The letter + appear after press 2 times quickly the button star ( * )
3 – The phone show “SIM Restriction Off” and was unlocked !
As with all unlocking codes off the internet I take no responcabilty if it doesn't work.
you use these tips, hints and sites
AT YOUR OWN RISK
thank you my lord me thinks ill leave well along regiment
AT YOUR OWN RISK
Nice work, ref unlocking the Nokia.
I'm a bit of a risk taker. Any suggestions how to unlock an iPhone 4?
This guide is for iPhone 4 running iOS 3.1.3 to 4.0. If you are running iOS version later than 4.0. This guide is not recommended for you.
The credit for this unlock solution for iPhone 4 goes to iPhone Dev Team. Without engaging you in more details, I'd guide you through 10 steps to unlock your iPhone 4. It shouldn't take you more than 5 minutes.
Let's start:
1. Connect your iPhone 4 to a wi-fi network. No 3G please.
2. Open the Safari browser on your iPhone 4.
3. Go to Jailbreakme.com and jailbreak your iPhone 4. Make sure you have the iPhone firmware 3.1.3 to 4.0. No less than 3.1.3, no 4.x.
4. Now go to Settings>General>Network and turn off 3G. That's why I asked to used a wi-fi connections in the first step.
5. Now that you have jailbroken, you have ‘cydia’ installed on your iPhone 4. Press the home button and find ‘cydia’ in your apps in the springboard.
6. In cydia go to search and type ‘ultrasn0w‘. If you are presented with version 1.0.1 or higher skip to step 10 below. If the ultrasn0w version is less than 1.0.1, follow all the steps below.
7. You can't unlock your iPhone 4 with an ultrasn0w version less than 1.0.1. You'd then need to bring over 1.0.1. For that purpose, press the ‘Manage‘ button at the bottom, select Sources>Edit>add. Then type ‘repo666.ultrasn0w.com’ in the text field without quotes.
8. Reboot your iPhone 4.
9. Go to cydia again, search for ultrasn0w. It must be on version 1.0.1 or higher now.
10. Now press the install button to install ultrasn0w.
11. Your iPhone 4 is now unlocked! Cheers!
if you remove cydia from your phone it will go back to being locked.
Once again I have not tested this out myself so can not say if it works or messes up your phone or not so.
TRY IT AT YOUR OWN RISK
Err, be careful jailbreaking an iPhone - it will void the warranty!
Appreciate you taking the time and trouble, but it seems I'm on to a no-brainer because my particular iPhone is running version 4.2.1 firmware.
My knowledge of the workings of the iPhone is limited, but, from the various snippets which I've heard, I'm led to believe that jailbreaking the phone is maybe not a good thing to do unless you're absolutely sure you know what you're doing.
All I know is that Vodafone have already ripped me off, so I was hoping it might be possible just to unlock the phone for use with my O2 sim. Vodafone says that O2 sim cards will not fit into the iPhone, but I read somewhere on the WWW that all you need to do is to trim the O2 sim with scissors to the same size as that of the Vodafone sim... if any of that makes sense.
The downside to unlocking (if it is indeed possible with Ver 4.2.1) is that I shall lose some of the iPhone's functionality which is provided with Vodafone, but I'd sooner that, rather than being ripped off by all their sneaky/hidden charges... which incidentally they don't warn you of when you sign their contract.
every sim card I have seen in recent years has been the same size, the only ones that were different was back in the early days of sim cards any they were credit card size. unless vodaphone have made a special card for the iphone only ,I can't see that.
Computers are my thing and yest jailbreaking your iphone will void any warranty. I am not a fan of the iphone myself, so my advice would be stick it on ebay and sell it then buy an HTC phone running android {-)
looked it up, and had a shock, the iphone 4 does use a cut down sim.
thats another reason not to bother with the Iphone in my book.
Yes the iPhone 4 (and 3G capable iPads) use a micro SIM as opposed to the standard mini SIM we've all been used to for a few years now. Some of you may remember that there was once a SIM card and that it was replaced by the mini SIM!
It is possible to get SIM cutters that are like a paper punch and will cure the mini SIM down to micro size. In NZ many of the Vodafone shops have them and will do it for you - no guarantees though :) I did mine to test in an iPhone 4 and it worked fine.
"I am not a fan of the iphone myself..."
Oh, I thought that you were - especially seeing as how you initially seemed to be familiar with the IOS prior to version 4.2.1
I'm now lead to believe that your reply in post #17 was likely just copied and pasted from one of the myriad iPhone hack pages gleaned from the Web. The clue is in the grammar and punctuation, which mysteriously just isn't there in your subsequent post.
Given that you obviously know damn diddly about the iPhone 4 and its capabilities, you will pardon me if I ignore your unwaranted biased comments regarding Ebay, HTC and Android.
Nothing wrong with a bit of cut and paste. It is just sharing knowledge.
For me, perhaps 90% of the work for most tech issues is finding the page/site on the internet that I need.
Just be careful that you don't go near Surrey Satellite Technology or your phone may be blasted into space!
"Mobile phone to blast into orbit"
my other half has had both the iphone and iphone 4 as work phones, so I do have use experience of the phones, and also sorting them when they freeze, won't connect, so take a chill pill and calm down. yes I did cut and paste from the internet, As I said at start my field is more computers than phones.
so calm down before you have a heart attack or something.
Absolutely. But only if the cut/pasted information holds true to the relevant question, and only if said information is used in a way as not to try to gain the credit for themselves.
And you're bang-on regarding 90% of information being feeely available to all - if one one cares to make the effort to look. For my part, devious scamp that I be, I had weeks ago already gleaned the information I was in need of; I just wanted to see if anyone who uses the word "Lord" in their handle really is as smart as they profess to be. Because one good advantage about heart attacks is that they give you a fresh insight of life. One is left with the ability to spot a phoney from a hundred paces.
@ Regiment:
Man, I do apologise for hi-jacking your thread. Yes, I did receive your PM. And yes, I'd sent you a second batch of switches last Friday. Surely you must have Rx'ed them by now?
@ Regiment:
In no post on here did I claim to be an expert, I did say I could normally track down codes, this is all, you asked if I could find anything on the iphone 4, this I did for you, all be it not ruining the OS you are using, If my use of the Name Lord Bungle does interest you my reply on the whats in a name thread on this forum will supply you with an answer.
As I have now learnt you have had a heart attack I do apologise for my use of the calm down before you have a heart attack comment.
And I do hope you have recovered from your and are now well.
LB
http://www.modelboatmayhem.co.uk/forum/index.php?topic=28178.0
