The Shipyard ( Dry Dock ): Builds & Questions => Pleasure boats, Sports, Race, Power and Leisure Boats: => Topic started by: gwa84 on January 09, 2011, 08:10:40 pm
hi guys ime looking for the above manual to sort an engine out what ime after knowing is what to connect the 2 nipples at the rear of the crank case to ive used engines with only one for pressurising the fuel tank but haven't come across one with two :-))
some picks
(http://i275.photobucket.com/albums/jj298/wiplash84/100_0887.jpg)
(http://i275.photobucket.com/albums/jj298/wiplash84/100_0886.jpg)
(http://i275.photobucket.com/albums/jj298/wiplash84/100_0885.jpg)
they are for water cooling just link with head tubes.
peter
Should only be for a water cooled back plate, remove and check to see, it will allow the backplate to be filled with passing water.
connect the water pick up pipe to the bottom nipple then another piece of pipe from the top nipple up to any nipple on the
cylinder head, than the other nipple on the head is the outlet.
Hope this is of some help.
Gary.
