Technical, Techniques, Hints, and Tips => Engineering Techniques and Materials. => Topic started by: boatmadman on February 27, 2007, 04:46:19 pm
I am looking around for a coupling for my 48'' steam drifter. The prop will be 60mm driven by a 12v buhler motor, although the drive train will be changed for steam plant when I get the steam stuff done.
Can anyone recommend something suitable? I have looked at dyco, but its hard to tell if they are man enough for the job.
Ian
Prop shop do excellent stainless steel couplings - but might be 3 or 4 weeks wait !
The Dyco couplings will handle the torque of either power plants.
Great, thanks Bob
Ian
Ian, have a go at your local garage, I know that Opel (Vauxhall in the UK) has some very good couplings with a hard-rubber adaptor which does a brilliant job. It`s used there to power the water pump.
The steel-claws you may drill the hole on a lathe in the dia as you need it....
If you can`t get it, we have an local vendor here in Germany which does it on the dia you need.
It´s called "Power-grip"-coupling and will be used in Powerboats as well.
Hope this was out of any help,
Jörg
Ian,
RS Components do a range of small flexible couplings that would probably be suitable.
Clive
Thanks for that clive
I know I keep mentioning them,
But the website has a good selection of his sometimes usefull wares,
http://www.prestwich.ndirect.co.uk/
Tug
Thanks tug, am sorted now, got some from westbourne.
Ian
