The Shipyard ( Dry Dock ): Builds & Questions => Pleasure boats, Sports, Race, Power and Leisure Boats: => Topic started by: petrolhead29 on May 03, 2011, 04:33:12 pm
OK was wondering if anyone knew where i would get a replacement prop for a joysway off shore warrior preferably brass as Ive been told they are more efficient, also is there any way of adding water cooling to a non water cooled esc
You could try making a half circle of copper pipe [or car brake pipe] at attaching this to the underside of the esc, then link it to the motors cooling system, as this puts more of the cooling pipe in contact with the esc, rather than looping it round "coil fashion".
if you check the measurements of the original propeller, then check out some of the prop suppliers, you should be able to find a suitable match.
There are ready made esc cooling plates available here;
http://www.offshoreelectrics.com/proddetail.php?prod=ose-80670
but could easily be made by soldering copper pipe to a copper plate.
Glenn
