Technical, Techniques, Hints, and Tips => Detail Work, Rigging, Fittings, Figures Etc. => Topic started by: rescue on February 28, 2007, 09:24:27 pm
a way to make false windows is
just use a peace of aluminum folio
fold it a bit
fold it back straight
put it behind a piece or clear styrene
than put the frame a round it and ready to and place it on the model
Edwin
Interesting idea! Usually I just paint over the back of the transparent styrene with darkish blue paint. Also works quite well. Actually, on models I think that "false" windows/portholes often work better than actual glazing.
found it out when i was trying to make a test window
tryed painting to but this way looked the best
edwin
Why not just leave one side of the clear sheet protective covering in place?
i don't use glass or styrene
i use sheets for the overhead projector
i could not find the words for it in Engels because its my 2e languish
Edwin
Edwin, we are all guilty of forgetting this from time to time,
"words for it in Engels because its my 2e languish",
I Wish I could communicate in another language as well as you can
[even make up a proper sentance would help]
We used to call this celluloid, but this is probably banned by now. Art shops supply this.
I knew it as acetate
Ian
Try microscope slides - but make sure they're accessible in case of breakage !
I am doing up a cruiser which has styrene windows. I wish to paint these on the inside and I notice that Colin suggests dark blue.
Unfortunately the superstructure is dark blue so dark blue windows might look a bit odd.
Has anyone used a different colour that would look alright.
Am asking because I am colour blind and I've only got one chance of getting it right.
Richard ;)
That's a bit of a poser! Maybe dark grey would work as it might suggest tinted glass....
Hi DD, might I suggest that you buy an artists tube of paynes grey acrylic paint. This is a very dark grey, when it is dry then paint it with a GLOSS varnish, this will make the colour recede and give it a glass glazed look. Hope this helps.....bigH
Cheers all.
How about I spray the inside with a grey primer.
Richard ;)
Just tried that on a bit of scrap Richard - no good, it's much too light a shade. Big H has the right idea, it needs to be a very dark grey. Even if you are colour blind you should be able to judge the effect for yourself using shades of grey. ;)
