Technical, Techniques, Hints, and Tips => The "Black Arts!" ( Electrics & Electronics ) => Topic started by: guitar man on July 24, 2011, 07:04:45 pm
Hi all
Can anyone tell me what happens to these connectors,do they have a male opposite that you can buy or are you meant to crimp them over in some way, have not come across these sort before. I may just cut them off and connect in another way buy would be interested to know about them
As always thanks in advance for any help
Regards Tony
(http://s3.postimage.org/1u2kwhves/P7240082.jpg) (http://postimage.org/image/1u2kwhves/)
(http://s3.postimage.org/1u2mk17wk/P7240083.jpg) (http://postimage.org/image/1u2mk17wk/)
(http://s3.postimage.org/1u2o7kkec/P7240085.jpg) (http://postimage.org/image/1u2o7kkec/)
hi,
are they on mtronks esc, if so they are bullet connectors i normally cut them of and use spade ones as you said
hi there
We used to know these as a 'bullet' connector - male and female - the one you show on the photo is the female. Several companies such as MTroniks and Graupner use these connectors on some of their speed controllers. The problem is if you cut them off you make your warranty on the speed controller invalid. I have found Halfords sell a pack of varying sizes of the male and female which I have used. They are pretty easy to crimp onto cable using a pair of pliers, but I have, in the past, used a small amount of solder to hold them in place.
aye
john
I agree with bluebird. If you can soider them. I also use heat shrink over the outer wire onto the connecter to
ensure the wire holds ok if pulled or flexed. John.
HI David yes they are off Mtroniks sounds like you have been there before ,thanks to the others for your speedy response.
Regards Tony
hi,
i have sent one back and they didnt bother as the fault was inside sent replacement unit great services can not fault them, yes been there you know the rest
davidj
Check out Flightline Accessories number HFL2025 bullet connectors, it's a pack of six male, six female and 12 plastic boots.
Roger
My sparky showed me some new connectors which are compact, simple to use and vibration proof - worth a look :-))
http://secure.wago.ltd.uk/shop/department/222_series/
hi,
davidj
It seems to me that is not saying a change of connector will void warranty, just that they wont cover changes to the connectors, ie if you change them they wont change the replacement ESC's connectors to what you put on. Could be wrong though {:-{
Its a standard connector Tamiya put on their motors \ Speed control, ordinary auto crimp bullets will work in them.
Nick
Bullet connectors over our way are quite common off the auto supply shelf - red and blue (wire size) - I use these quite often, just remember to add coloured tape to your wires if using for power where + / - is critical. The trick is to crimp these well - tinning the wire first helps.
