Mess Deck: General Section => Tugs and Towing => Topic started by: Gerryg on October 14, 2011, 03:49:05 pm
Hi being new to building boats I was just wondering if anyone can answer a question for me when using a fibre glass hull how do you seal the prop shaft from the water. I know in a real ship you have a packed gland is it the same on a model boat ?
For sealing between prop shaft and hull use two part epoxy resin.
I use Zap Z-Poxy 5 Minute Formula 8oz Set
http://www.cornwallmodelboats.co.uk/acatalog/epoxy_glues.html
To seal larger gaps use P38 car body filler or even larger gaps use P40 car body filler available from Halfords
Thanks for the info Richard so the shaft just runs in the drilled hole do you need to lubricate the shaft as it's runnig on the bear fibre glass ?
Im wondering if theres a misunderstanding here.
You usually have an outer shaft which is bonded into the hull in the manner described.
Inside this outer shaft / tube is the running part of the shaft which is usually watersealed and lubricated using various types of grease - personally I use the green gunky grease thats used on bicycles for lubricating gears - this is an ideal silicone based lubricant
There is a huge amount of advice on the forum about prop shafts if you use the search facility from the main forum page.
Use keywords such as propshaft, prop shafts, oiling etc.
Thanks guys I have got it now so the prop shaft runs inside a bush glued to the hull !
Not quite!
The propeller shaft runs in a tube fitted with bushes at each end which is fitted and glued into the hull. Some form of lubrication is then used within the tube although nobody can agree what is the best type!
Photos of some prop shafts.
http://www.cornwallmodelboats.co.uk/acatalog/Raboesch_Precision_Propshafts.html
A very rough drawing of what they do
Mark
(http://i259.photobucket.com/albums/hh293/craftysod/Scan1.jpg)
Gerry it is also possible (depending on the type of ship) to fit the propshaft at an angle so the inner end is above the water
so that you only need a small amount of oil for lubrication only - this is quite common on warship models.
Geoff
Thanks all got it now.
