The Shipyard ( Dry Dock ): Builds & Questions => Yachts and Sail => Topic started by: Patrick Henry on October 28, 2011, 09:39:33 pm
Ok, just going through my list of bits to get for my Gemini cat...
I want to change the horrible wooden framework that holds the two hulls together and supports the main mast for carbon rod...but(here comes the question)where do I get carbon rod and what sort of diameter would I need?
This is how I'm thinking of doing it....
(http://s7.postimage.org/6jqxnnefr/RC65_Adrenaline_b14.jpg) (http://postimage.org/image/6jqxnnefr/) (http://s7.postimage.org/eivaiptjr/RC65_Adrenaline_b6.jpg) (http://postimage.org/image/eivaiptjr/)
Instead of this...
(http://s7.postimage.org/v2xkip87r/cat3.jpg) (http://postimage.org/image/v2xkip87r/)
Any advice, guys?
I have been looking at Carbon rod for another project. It looks to me as if carbon tube might be a better bet for you - it would be stiffer and might be easier to fix at the ends. It's difficult to recommend a size as there's not much in the photos to scale them by.
Just possibly an old fishing rod may provide what you require.John.
Sorry, my mistake...I should have written 'tube' instead of 'rod'...
Fishing rods...I tried a old rod I found, but the sections are tapered, aren't they?
It's been suggested that alloy tube from B&Q will do the job nicely, so I'm going to try that first, I think.
Look for a shop that specializes in selling kites.
unicorn
try
http://www.giantcod.co.uk/carbon-fiber-tube-hollow-d60%C3%83%C2%97106050%C3%83%C2%971m-5pcs-p-403653.html (http://www.giantcod.co.uk/carbon-fiber-tube-hollow-d60%C3%83%C2%97106050%C3%83%C2%971m-5pcs-p-403653.html)
if you cast around on the GiantCod website you'll find they do 3mm and 6mm tubes and strip and rod too
Richard
Now we're getting somewhere...thanks Richard!
I guess 6mm would be the size to go for to make up the cross spars?
The r/c helicopter guys use a lot of carbon fibre tube and rod. look on their websites.
Try here:
http://www.easycomposites.co.uk/Category/Carbon-Fibre-Products/Carbon-Fibre-Tube.aspx
Chirs
cheapest place for carbon tube would be a kite supplier model shops tend to ask the earth for carbon stuff.
http://www.thehighwaymen.co.uk/acatalog/Single_line_kites.html
Thanks for all the valuable help chaps, it's much appreciated.
I think carbon tube may be the way to go, I'm told to think lightness above the waterline, weight below.
Thanks again,
Carbon fibre will be less than a third of the weight of aluminium.
I would go for the giant cod 6mm stuff. The kite shop CR tubing looks like it is a thicker laminate- stronger but heavier.
All done...just bought the Giant Cod 6mm stuff, more than enough there for the cross pieces and maybe even the mast as well.
Thanks everybody,
Glad to help Rich,
Could you post some photies when you've finished ?
cos I've been thing about building a catamaran with
carbon fibre tubing to hold the hulls together
Richard
No problem Rich...I'll take plenty of pics as I go along. It's only a cheapie of a kit, but I think with a few mods along the way we can do something with it. I chose it because it's only a small boat, it fits in my flat and my car nicely, and our local lake isn't really big enough for big boats.
