The Shipyard ( Dry Dock ): Builds & Questions => Navy - Military - Battleships: => Topic started by: Ted_H on February 18, 2012, 11:15:11 pm
I'm still on with the build of my type 81 HMS Nubian.
However on the flag deck (above the bridge)there are 4 positions for air lookout posts. I understand these are seated positions inside a round tube with a framework for binoculars.
unfortunately I cant find any reference or pictures of these.
Could anyone help me either with a description or a photo of such so I can model them.
I'm building in 1/96 so fine detail wouldn't be too important, although I like to do as much as I can, more than just an emty tube.
Ted :police:
I've built the Deans HMS Nubian, piccies on this site just search for nubian, but I doubt if the piccies would help you in this instance. There are some upgrades from the Deans fittings though, including a Wasp helo and wood decking and I also souced the 20mm oerlikons elsewhere.
Sorry Ted all photos I have of this area of the ship - the lookout sights are covered in canvas covers.
From the plans I have and from previous builds I will be using 9.5 mm evergreen tubing - it is the perfect size.
It needs a large (about 8mm hole cutting in the side for the legs to stick out then it needs a frame and footrestcoming out the bottom of
of the hole a small seat base inside and and seat back - these were both painted brown as I think they were leather or pvc.
the top of the tubing needs a piece of plasticard about 1.5 wide sticking round the top and then carefully filing off at an angle so that it
sticks out more at the bottom - this painted white to simulate the 6 inch wide canvas screen which could be pulled up in bad weather.
then I used some .5 rod to simulate the binocular support bar with a couple of short rods of .7 in the middle to for the binocs.
Hope that makes sense as I have no pics at present
Geoff
A bit before a Type 81 Frigate
More like a Tribal Destroyer methinks
Ned (1st Commission HMS Eskimo 1962-64)
Thanks to those who replied.
I am building a type 81 on a Deans marine hull. However all the years ago when I bought it I only purchased the hull and a quantity of plastic card sheet. The rest I'm constructing from scratch using photos,and differing parts of plans.
Fortunately since I shelved this build many years ago the internet has become more available for research. That is how I found there something to be missing from the information I have about these air lookout posts, that and a chat with a collegue who served on Nubian. (I have a builders plan that shows them, but no information).
Thanks Geoff for your informative description, it fits with what I had in my mind and the dimensions you give are most usefull
