Mess Deck: General Section => Full Scale Ships => Topic started by: hemayann on April 17, 2012, 10:25:02 am
i have a motor thats marine 39hp, the shaft is 1200mm, what size boat and prop can it handle?
i need a formula?
does it matter how long the shaft is?
39 horse power should get you across the pond. %)
ha its for a big boat :-))
na i've got a 25 ft clinker boat its got a 12hp yanmar n a 28mm saft n a big prop
is that a full scale boat??
1 to 1 scale
out my depth here {:-{
(http://s11.postimage.org/qq2p5l9wf/DSCN0678.jpg) (http://postimage.org/image/qq2p5l9wf/)
(http://s11.postimage.org/677t0ivz3/DSCN0676.jpg) (http://postimage.org/image/677t0ivz3/)
here she is
Think you need to join this lot matey .....They might have a lot more knowledge about this sort of thing than we mere modelling mortals will have about the subject........
http://www.classicboat.co.uk/forums/forumdisplay.php?f=17
neil.
I suppose the principle is the same but on a larger scale. When we over prop we get heat and smoke but were on the bankside not sat in the boat smoking with it! %% %%
Be nice to see it with a brushless setup {-)
ha i know there is some brainy people on here
Size of boat and prop will depend on whether you want to go watersking really {-)
well, a good question like yours brings out the brainiest of us, lol {-) {-) {-)
yes there are several formulas kicking around, along with several charts to give an approximation of:
: prop size and pitch for a known horsepower and rpm of the motor
: if the boat's weight and size are known & you know what speed you wish to go - there is a formula for that as well
but first of all; you need several known factors
output shaft rpm of the motor, weight of the boat (in this case its going to be a displacement weight) and we need to calculate the block co-efficient
For a semi displacement hull, the block co-efficient should fall between 0.4 - 0.45
For a displacement hull, the block co-efficient should be between 0.45 - 0.55
K = speed in knots
Bhp = brake horse power at the propeller
K x √bhp
displacement in tons
This should give you some idea of the formula which you require
Aye
john
told you there is some brainy people here
cheers mate it'll help lots
