Technical, Techniques, Hints, and Tips => The "Black Arts!" ( Electrics & Electronics ) => Topic started by: cos918 on June 06, 2012, 03:19:20 pm
Hello
I am trying to find these LEDs at a better price as I need a fair amount of them
http://www.maplin.co.uk/side-looking-leds-10382.
If you know any suppliers can you post a ink if posible. Have tryed Ebay but can not find them on there.
Here are some that are a little cheaper John,
http://www.expressmodels.co.uk/acatalog/WHITE_LEDs.html
Ali
Try Component shop WWW.component shop.co.uk
Hi Ali
Its A bit cheaper thanks.
Hi Dave
tryed them they dont do that type pity as there prices are great but thanks any way.
john
These may help,
http://www.ebay.co.uk/itm/LED-WHITE-SURFACE-MOUNT-DEVICE-20PCS-PER-LOT-3-2MM-X-2-8MM-/260892542371?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item3cbe6845a3
Otherwise search for "Surface Mount LEDS" in search bar.
Regards Ian.
Cos918 did u contact them
These may help,
Regards Ian.
Hi Ian
thanks for the link but thoes are not the LEDs I am after
john
Just looked at there web site
Get the tel no off the website and give them a ring wont do any harm
Not sure if this place does side mounted leds but check them out http://www.phenoptix.com/index.php/surface-mount-smd.html
For us uninitiated, what is the difference between "standard" and side mounted and now surface mounted LED's as per the last couple of links {:-{ {:-{
Surface mounted:...................... http://www.phenoptix.com/index.php/surface-mount-smd.html
Side mounted:........................... http://www.maplin.co.uk/side-looking-leds-10382
Also where would you use them on boats.
Thank you
Thank you
Standard - tubular resin thing - domed top, two wires poking out of the blunt end to poke through a PCB and solder to the back, light shines out the dome. Commonly 5 or 3 mm diameter, but can be odd shapes.
Side mounted - two wires as standard, but arranged so that the light shines out of one side. Again, various sizes and shapes available.
Surface mount - no wires, just two metal areas that solder direct to the metal on the PCB, the light can shine which ever way that the manufacturer decides. SMD was intended to aid miniaturizing electronic gear, the LEDs tend to be small.
The led's can be built into bulkhead/deck lights around your model to light up the deck, can also be built into a wheelhouse computor screen I know Umi has done this.
Brian
Not quite what you are looking for but theses are very good
http://www.dccconcepts.com/index_files/Prewired08mm0603SMTLEDs.htm
The possibilities are endless
I have some of these as well
http://www.dccconcepts.com/index_files/DCC_loco_lamps.htm
thought they might look cool on my CUX 87 as well
Malcolm, Thank you, understand what I am looking at now :-)) :-))
Brian
Brian,
Thank you, yes handy items :-)) :-))
Ebay . Ive just got about load of them for pennys an the restistors too with them
The guy i deal with is fair priced an keeps you informed
Hi There
I have just done an ebay search using the phrase ( side mounted led ) and there is none. Do you have a link to the seller or a link to a sales page
thanks
john
Hi there . Yeah i think i may have got crossed wired here . There no side mounted but should be easy to make . I use to make light units for n gauge union pafic locomotives . And my cousin had n gauge cars with head lights turn on an off . The seller sales micro leds .his seller name is handsignalman. The leds i had off him are
Really good for value an with the restistors . I call it a bargin
Hello
It has to be the side mounted LED as the look life floursent light fittings at 1:100 scale.
Micro leds surface mount leds etc I have no problem getting hold of at good prices. The side mount led are still a bit pricey at 65p each when you buy a lot of them.
john
Have you Rapid.
www.rapidonline.com
They do surface mount right angle LED's and miniature LED side viewing.
http://www.rapidonline.com/Electronic-Components/3010-Right-Angle-SMD-LEDs-517579
http://www.rapidonline.com/Electronic-Components/Optoelectronics/Through-Hole-LEDs/Miniature-Led-1-5mm-Side-Viewing
Alan.............
Hello
Thank you for the link put they are not the ones.
The led I am after are like in the photo below.
SSB-LX02
That te best i can get you Cos..but at least you have a general part number not a decription .
http://www.futureelectronics.com/en/technologies/semiconductors/optoelectronics/led-segment-displays/Pages/1174622-SSB-LX02YC.aspx?IM=0 (http://www.futureelectronics.com/en/technologies/semiconductors/optoelectronics/led-segment-displays/Pages/1174622-SSB-LX02YC.aspx?IM=0)
http://www.google.ca/search?q=SSB-LX02YC&hl=en&tbo=d&rlz=1T4GZBN_enCA497CA498&source=lnms&tbm=isch&sa=X&ei=p4UdUcO6D6m90AGTvYC4DA&ved=0CAoQ_AUoAQ&biw=1366&bih=680 (http://www.google.ca/search?q=SSB-LX02YC&hl=en&tbo=d&rlz=1T4GZBN_enCA497CA498&source=lnms&tbm=isch&sa=X&ei=p4UdUcO6D6m90AGTvYC4DA&ved=0CAoQ_AUoAQ&biw=1366&bih=680)
thanks for that. That electroins store looks cheeper at about $.60 wich is about 44p inc vat which ant bad.
certainl beat the rip of britian suppliers.
Thanks for this info - these look perfect for 1:96 flourescent strip deck lights on the ferries.
Absolutely spot on size!
Will need about 40 for the Free Enterprise V....better get ordering :-))
Carl
