Technical, Techniques, Hints, and Tips => Painting, Finishing and Care. => Topic started by: morton on June 08, 2012, 03:09:25 pm
hi, what type of paint would you use for keel and hull for clyde puffer. colour ect.john.
I used normal Red Oxide primer - http://www.wickes.co.uk/all-purpose-primer-spray-paint-red-oxide/invt/194167/?source=123_74
hi, do you varnish over the top of the red oxide, cheers john.
no need to at all BUT if you decide to do so then a satin varnish would surfice
I have always understud that primer is not waterproof. Halfords isn't.
Joe
NO primer is Waterproof but as it will probably be a plastic or Grp hull then being waterproof or not it wont make an iota of a difference
