Mess Deck: General Section => Chit-Chat => Topic started by: Nordsee on June 10, 2012, 06:23:49 pm
Just to say I am back, I haven't really been away, just moved home, from one town to another, which here in Germany is quite complicated with registering with all the Offices and changing addresses etc. When I finally got settled in and the Internet in action, I went onto Mayhem and discovered I had been deleted, Painfull! I re-registered ( with old name) and here I am, sadly all my photos seem to have gone as well, shame as they were the only copies I had of some of them. Give me time to get my new cellar room set up and I will be back posting with the rest of you. Till then.....
Welcome back.
Welcome back ..too bad about the pictures. Can the Master (Martin) not work his magic to recover them ? BTW where are you now ? (approximation will do).
He,s still in Deutschland,
Neer eenuff Wull. :-))
Good one Wullie, we got it here also O0 O0 O0
I only moved about 20 odd miles, but changed my County, hence the palaver. New number for the car, telephone etc. If my old Galerie could be recovered I would be very grateful, a difficult request I fear. I have a new Club as well, they are Racing orientated with IOMs and Marbleheads and take it very seriously, but they tolerate my style of boat so that is OK. Maybe I can get some of them to build a "Proper" model boat (?)
I would not say that about building a proper boat out too loud if I were you, you might get a pair of concrete shoes for your trouble, LOL. Mick B.
For making enough quick setting concrete,..to cover legs up to shins,....solid withing 15mins,use 25kg 20mm chuckies,(gravel)15kg sharp sand,10kg Portland cement,..enough water to mix,then after all are mixed together,..add the setting agent,...10kg Carlite Finish Plaster,...mix this in then pour into big bucket that contains some poor sods tootsies,..make sure he/she is held firmly as the mix will generate heat whilst setting, {-)...solid after 15mins ...after a couple of hours you,ll need a Kango Hammer to remove if you,ve changed your mind, {-)
I wont ask "how" you know this lol
Now you know how Al Capone & Co, did it,....also great for fixing fence posts into ground...much cheaper that buying Postcrete from B&Q @£6 per 25kg,
Oh, and thanks to the kind member for adding my name in lights,.... {-) {-) {-) {-) {-)
You were already a star Wullie. %)
Hi Nordsee
are your old posts still in you name or missing or in someone elses name?
I just thought I,d let the rest of my admirers see my name in Lights, {-)...Flashing Wullie,...not to be confused with Wullie the Flasher, {-)
You've had it lit up longer than I expected Wullie
;) ;) ;) O0 O0 O0
It was nice while it lasted,...many thanks to he who did it, and to the other who helped,as for those that did,nt like it,...well,my :-X :-X :-X :-X :-X :-X :-X
