The Shipyard ( Dry Dock ): Builds & Questions => Navy - Military - Battleships: => Topic started by: gra2 on July 21, 2012, 07:30:15 am
Some early photos of my Whaleback build long way to go.Bluebird and Christian have helped me out with some photos which i thank them for once again.
I would i like a photo or a sketch of the small winch on the bow if somebody can help.
(http://s14.postimage.org/h9u99vll9/DSCF1529.jpg) (http://postimage.org/image/h9u99vll9/)
(http://s17.postimage.org/4ttv56b2j/DSCF1533.jpg) (http://postimage.org/image/4ttv56b2j/)
(http://s8.postimage.org/p2kq9o1gx/DSCF1531.jpg) (http://postimage.org/image/p2kq9o1gx/)
(http://s9.postimage.org/3y1dfmjez/DSCF1535.jpg) (http://postimage.org/image/3y1dfmjez/)
Thanks Gra
The hull is from Model Boatshack.
Gra
Bout time your building a model of a proper scale - BB won't be sailing all alone anymore O0 %) :-))
Mdu
No reply to my first post for some info on the bow winch.
Anybody out there that can help please.
Thanks Gra2
Have a look at Marks Model bits selection of winches.
http://www.marksmodelbits.com/
gra 2 hi there
Nice to see you progressing well with the ~Whaleback~ as far as the Anchor Windlas goes, I dont have any photographs now of the Windlas on the whaleback
however, the same windlas was used on several air sea rescue launches and it is the same Windlas on the RTTL
I have carried out a websearch and I can only find images of the modern version of the Windlas - the version you require is a mechanical one - where it has the socket at the stern for the operating handle. I will put a few photographs on of the RTTL one - also Maxmouldings do a 1/24 version - I know its too small for yours; but it will help you when you are scratch building one for your required scale.
http://www.macsmouldings.co.uk/data/storage/attachments/2ac261b924a07b65f78a6ab82f3f5910.jpg
aye
john
G/day
Thanks Ken and John i will see how i go with your info and photos.
Gra2
G/day,
Winch completed plus cleats and vac formed cowls.
Gra2
(http://s12.postimage.org/ndx6p1qdl/DSCF1538.jpg) (http://postimage.org/image/ndx6p1qdl/)
(http://s9.postimage.org/en275k1uj/DSCF1537.jpg) (http://postimage.org/image/en275k1uj/)
(http://s10.postimage.org/iud4y1is5/DSCF1539.jpg) (http://postimage.org/image/iud4y1is5/)
If you don’t mind could you cover how you made the Cowls? I’ll be making some for a future project would love to see details!
Cowls info - yes please O0
G/day
Will take a photo and show you my method.
Been in Hospital.
Gra2
Sorry to hear about being in the Hospital, I hope everything is ok. I am looking foward to the pictures - but please no hurry take care of yourself first :o
G/day Rmay and Dave,
Hope photos help method is the same as other members use on this forum.My experience is that you will loose some during the process.Sometimes you will get one first try.
For these cowls i made my tooling from timber but i placed a steel washer on the entry of the female tool glued with epoxy 5 min.gives a nice flat landing.
Material is polystrene sheet and rod from Evergreen.
I heat the kitchen oven to approx 250deg cross the fingers and away we go.Use a plastic filler to blend in upright and cowl once glued together.
Gra2
(http://s13.postimage.org/j08ql8atf/DSCF1542.jpg) (http://postimage.org/image/j08ql8atf/)
(http://s17.postimage.org/pa4xb2nl7/DSCF1543.jpg) (http://postimage.org/image/pa4xb2nl7/)
(http://s17.postimage.org/q9ztkis4r/DSCF1544.jpg) (http://postimage.org/image/q9ztkis4r/)
One more photo.
Gra2
(http://s8.postimage.org/46nx8pj5d/DSCF1545.jpg) (http://postimage.org/image/46nx8pj5d/)
Very nice - Thanks GR2 for the info and pics.
G/day
A little more progress.
(http://s12.postimage.org/qhgqul81l/DSCF1557.jpg) (http://postimage.org/image/qhgqul81l/)
Gra
Looking good, following your posts with interest :-))
Couple of questions
What thickness card did you use to mould cowls?
How did you form the deck lights in your last pic?
regards
longshanks
Hi Longshanks
I used 1mm thickness for cowls.
A fellow club member made decklights for me on a Pantograph Machine.
Gra
Why cant i post photos on this subject any more.
Graham
Hi some further progress.
My last comment should have a photo.
Gra
Graham
Can you go over to Photobucket ? There was talk of 'Post image' being a problem on here.
Thanks for reply Ken not sure how to use photobucket.
Why has postimage stopped working it has been okay in the past.
Graham
For the simple reason that the website template makers, (NOT Martin), are too bl**dy lazy to make sure ALL coupling software is totally compatible.
Part of a mate in Michigans job is to ensure that all new teknowleggy can comunicate with the data base of the company he works for. Due to the ongoing complaints about the MHS administered forum sites (ME, MB etc.) he had a look at the structure and said the most complained about problem was an easy fix. Two years later, it's still a pigs ear.
Sadly when you buy a program(me), it has to be trimmed to suit, pity the originators don't loose wages until it's sorted - - - Spline chunk needs you to "Allow pop-ups" and (http://www.modelboatmayhem.co.uk/forum/index.php?action=dlattach;topic=11159.0;attach=115774;image) £
Regards Ian.
WOW! WHEN WAS THAT ( (http://www.modelboatmayhem.co.uk/forum/index.php?action=dlattach;topic=11159.0;attach=115774;image) ) FIXED.
Hmmm The Pound sign ISN'T fixed, it just looks that way when you're signed in. Sorry Martin, 1 out of 10.
Graham
Just trip over to them and sign up. Then start a folder and upload your pictures.
When you view your picture and click on it, a box will open up Image links on it
Click on HTML code and it will say 'copied'
Come back here and paste it into your posting.
My doggie
(http://i129.photobucket.com/albums/p240/tug---kenny/Scout-2.gif)
The advantage of this method is that you can add further writing under the picture. :-))
Hope this helps
Hey.. whappets! These are mine...
Ahhhhh !! lovely.
Lets give Gra2 back his thread. Sorry about that but a lot is talked of the image posting lately. I'm sure it will come out all right in the end.
Ken
<a href="http://s1358.beta.photobucket.com/user/gra28/library/ (http://s1358.beta.photobucket.com/user/gra28/library/)" target="_blank"><img s
rc="http://i1358.photobucket.com/albums/q776/gra28/DSCF1605.jpg (http://i1358.photobucket.com/albums/q776/gra28/DSCF1605.jpg)" border="0" alt="Photobucket"/>[/url]
Another try for photos.
I clicked on IMG code which copied it.
I came back here and pasted it.
It works. :}
To get the effect you achieved you must have clicked the A href section. Have another go.
(http://i1358.photobucket.com/albums/q776/gra28/DSCF1597.jpg)
Another try Ken using your feedback.
(http://i1358.photobucket.com/albums/q776/gra28/DSCF1600.jpg)
Looks like i might have it Ken.
If it continues okay will organize some more photos.
Gra
(http://i1358.photobucket.com/albums/q776/gra28/DSCF1603-1.jpg)
A shot of the bow working on the superstructure at the moment.
Thanks again Ken for your help.
Gra
Glad you're sorted. Computers eh !"!!
(http://i1358.photobucket.com/albums/q776/gra28/DSCF1613.jpg)(http://[img width=650 height=487]http://i1358.photobucket.com/albums/q776/gra28/DSCF1613.jpg)http://i1358.photobucket.com/albums/q776/gra28/DSCF1613.jpg[/IMG]
A few more photos i hope.
Gra
(http://i1358.photobucket.com/albums/q776/gra28/DSCF1610.jpg)
(http://i1358.photobucket.com/albums/q776/gra28/DSCF1608.jpg)
(http://i1358.photobucket.com/albums/q776/gra28/DSCF1611.jpg)
(http://i1358.photobucket.com/albums/q776/gra28/ASRL13101.jpg)
Trial run last Sunday.
Gra
nice :-))
What did you use for the scramble nets? Do they unroll?
Hi Dave,
I used rigging twine dyed with a tea bag.I layed out the shape based on the plan with lots of nails around perimeter and tied of each
square with fine twine and a small dab of s/glue.
Net could be rolled down but i have tied it down on deck.
Graham
(http://i1358.photobucket.com/albums/q776/gra28/DSCF1674_zps59aa6709.jpg)
Started on turrets photo of 1st effort looking for suggestions for frame material.
On this frame i used double sided tape and normal paper .
Gra2
Lithoplate or Alluminininium S/A Duct tape?
Regards Ian
Yes try Lithoplate. I was lucky enough to get some from a friendly Printer; nice chap and he wouldn't accept anything in return. One type was smaller and thinner sheets (used) but the second lot was unused, thicker, and huge sheets from a defunct machine. Winner :-)) He said he was much happier giving it away for a good use than scrapping it for a few quid.
If you need the thicknesses I can go out and measure it - it's snowing just now.
http://www.modelboatmayhem.co.uk/forum/index.php?topic=9758.msg99138#msg99138 (http://www.modelboatmayhem.co.uk/forum/index.php?topic=9758.msg99138#msg99138)
Hi Graham you can try .5mm thick plastic card as I did on the one I built but I made a jig to keep the shape of the turret
by the way your model looks spot on
aye
john
(http://i1358.photobucket.com/albums/q776/gra28/DSCF1686_zpsa4dea155.jpg)
Thanks for advice Ian, Dave and John a bit slow getting back have beeen working on boat.
Some more work on turrets, nav lights and rigging and boat will be finished.
Graham
(http://i1358.photobucket.com/albums/q776/gra28/DSCF1687_zps9f5fd89e.jpg)
Another photo.
Graham
Hi gra2........never having worked on such small craft {:-{ ....so how did the crew enter & get below decks?...........
Via the hatch just FWD of the rear machine gun tub?...........Derek
Hi Derek,
The hatch forward of the rear turret was an escape hatch,the hatch behind the rear turret was the engine room hatch.
Trunk hatch on the port side of s/structure was for stretcher cases and the crew compartment hatch was forward at the bow.
Skippers conning hatch is next to searchlight.
Graham
(http://i1358.photobucket.com/albums/q776/gra28/DSCF1694_zps8decb965.jpg)
On the water photo with a bit of shadow.Hope to get some speed shots in the next few weeks.
Graham
Very impressive. :-)
Gra,
You progressed the beasty well, actually its an outstanding model. Will we be seeing the Whaleback at the lake this weekend :-))
Might bring BB for company %)
Mdu
Hi Martin,
Yes i intend to bring to lake on sunday.
Graham
Looks good
Any video to come?
Thanks for the comment Dave.
I presume you mean youtube i might give it a try,did some more work on turrets today and added life lines.
Few more items to go and it will be finished hope to get some action photos this coming sunday.
Graham
(http://i1358.photobucket.com/albums/q776/gra28/DSCF1706_zpse9dbd37b.jpg)
Hi turrets finished lifelines added plus aerials have to remake rear aerial it should have four lines not three.
Just need nav lights and lifebuoys to finish.
Graham
(http://i1358.photobucket.com/albums/q776/gra28/ASRL131-12a_zpsb12f035c.jpg)
Last post fouled up hope this works. Removed. Moderator.
Gra
(http://i1358.photobucket.com/albums/q776/gra28/BraveampASRL-04a_zps874eac6c.jpg)
In company with Martin 13 Brave Borderer both 1/16 scale.
Martins boat ran very well.
Gra
(http://i1358.photobucket.com/albums/q776/gra28/ASRL131-06a_zps058e3430.jpg)
Another action shot.
The lake the photos are taken at is in the centre of the Australian Grand Prix track which takes place next weekend.
Gra
Gra
Was great to see both models up on the plane but was surprised by the difference in hull size being the same scale. Must admit though, with all the pics taken on the weekend, this one's my favourite.
The whaleback turning out to be a fine model indeed :-))
Martin doon under
(http://i1358.photobucket.com/albums/q776/gra28/DSCF1724_zps59daff1b.jpg) (http://s1358.photobucket.com/user/gra28/media/DSCF1724_zps59daff1b.jpg.html)
Hi gentleman in photo is Geoff Edmonds Geoff served with 48ASR unit at Tenby and with LRRC unit 102 on Fairmiles.
Geoff is 93 years old and still very sharp.
Gra2
A few more action shots.
(http://i1358.photobucket.com/albums/q776/gra28/GS-01a_zpsb9ba4231.jpg) (http://s1358.photobucket.com/user/gra28/media/GS-01a_zpsb9ba4231.jpg.html)
Photo not working will try later.
Graham
Another one.
(http://i1358.photobucket.com/albums/q776/gra28/GS-03a_zpsf18ef6ee.jpg) (http://s1358.photobucket.com/user/gra28/media/GS-03a_zpsf18ef6ee.jpg.html)
Graham
Stunning! The turrets looked like quite a challenge.
