The Shipyard ( Dry Dock ): Builds & Questions => Pleasure boats, Sports, Race, Power and Leisure Boats: => Topic started by: Steve on August 11, 2012, 11:09:23 am
Hi guys, can anyone tell me what wood was used on the decks of the original Huntsman 31?
And on the subject of motor mounts what is the best way of securing a motor mount to a fibre hull?
Steve.
best way is to rough the inside surfaces and use epoxy resin
the full size ones are teak decked .
Thanks for that, I had it in mind it was teak but just wanted to confirm it.
Steve.
try a watercooled brushles mount just glass it in the hull, you can use a brushed motor in them, I have seen a few huntsmans with fiberglass hulls using this type of mount
Peter
Yep thats the mount I have in mine, with a BL outrunner.
I laid up 2 6x6mm wooden runners into the base of the hull for the mount to screw into.
