Technical, Techniques, Hints, and Tips => GRP & Epoxy => Topic started by: Lash151 on August 13, 2012, 08:08:25 pm
Hi...
I just bought some UHU Acrylit off fleebay... the instructions are all in german! Can someone guide me on the mix proportions please... it has a little spoon with a different size bowl at each end, some powder and the glue... any advice would be appreciated... thanks
Lee
Quoted from Mike Weston's site
"Use and Handling Instructions
Surfaces must be dry and free of dust and grease. Roughen smooth surfaces. Fill the mixing tube with strands of binder between two of the marker lines. For every square covered by binder add one small measure (one large measure for every two squares) of hardening powder and mix thoroughly using the spatula. Apply a thin layer to both surfaces and hold in place for approx. 15 minutes. No need to apply much pressure"
Good stuff too, I did my Micro Magic partially with that. :-)
Thats great, thank you...
Lee
Bloody hell... it doesn't half dry quickly!!! You have to get the piece in position pretty fast!!
Lee
'blinking!' hell... it doesn't half dry quickly!!! You have to get the piece in position pretty fast!!
Lee
Yes I should have mentioned that..... %% Does a good job though.... :-)
