The Shipyard ( Dry Dock ): Builds & Questions => Submarines => Topic started by: rnli12 on September 28, 2012, 08:51:28 pm
Hi all,
I have a unknown make of 'Los Angeles class' measures 45" x 6" x 6" hull fitted out with water/air tank system, it runs on a 12v battery with 540 motor driving a 55mm 7 blades propeller. Any ideas if the motor/prop combination is to much seems very nippy. Looking to overhaul the boat slowly.
Any other advice grateful received.
Can we have some pictures, please?
Depends on the wind on the 500 type motor. One with a lot of turns can pull a prop that size direct drive, and assuming the pitch is no greater than the diameter (e.g. 1:1 or thereabouts) similar powertrain is fitted to the Engel Lafayette, and that nips along too- streamlined hull form.
Generally for a prop that size you shoud be looking at a prop speed of between 2000-500RPM, depending on prop pitch, speed you want, and running time. There are only a two or three companies I know of that make scimitar props, one is Raboesch, another is Prop Shop and I think George Sitek makes them too. Raboesch are pretty much all 1:1 or 1:1.1 pitch to diamter ratio. Prop Shop tend to be higher in pitch, so you usually need to dial the RPm down a bit. Don't know about Sitek props, never owned one.
Carson toxic 540 can motor sounds a good bet... 6200rpm@7.2V
Thanks for the responses, I have attached some photos of the model, its a direct drive 540, with a homemade prop but I have seen a seven blade 55mm on CMB 55mm M4 Threaded 7 Blade R/H Brass B-Type Propeller or L/H.
i guess the scale is around 1/96 or 1/72?
Thanks for you support.
Looks like an MMB LA to me http://www.marksmodelbits.co.uk/ (http://www.marksmodelbits.co.uk/) Strange internal layout though, I'd have expected to see a cylinder in there, that's how I built mine. Scale is around 1/80th....ish.
(http://s12.postimage.org/lj6lpabm1/p2407110.jpg) (http://postimage.org/image/lj6lpabm1/)
Mine had an ACTion 550 motor, direct drive, to a 60mm seven blade scimitar prop...if I remember rightly I got it from Deans Marine, so it was probably a Raboesch one.
Rich,
I now realised I have seen the model before at MMB! Your layout seems much neater have you got any details of what you have used and where from please? Is your a direct drive with a 60mm prop?
Think I will change the motor soon a go to a 60 mm prop.
Hi Rich,
My cylinder is an IDIDIT...if you pop over to http://www.theassociationofmodelsubmariners.com/t200-la-class-semi-kit (http://www.theassociationofmodelsubmariners.com/t200-la-class-semi-kit) you'll find my build log of the boat, save me repeating it all on here.
Many thanks Rich
My pleasure Rich...
It definitely isn't one of mine...... The bow, stern, hull/deck split is different & it is 8" too short as well.....
Mark,
I was just thinking that may drop you a pm next week when I get my head around this one!
It could well be a scratchbuilt hull. LA class is a farily straightforward shape, being largely cylindrical with taped bow and stern, so it suits construction from PVC pipe, with grp nose and stern.
Be careful going too large with a single prop, this moves the torque lower down, which is more efficient, but can roll the boat over under power.
