Technical, Techniques, Hints, and Tips => BRUSHLESS Motors and Speed Controllers => Topic started by: emeandy on January 01, 2013, 06:32:07 pm
Hi I'm looking at buying a turnigy 2s 5000 mah 40-50c and a turnigy 3s 5000 mah 40-50c so will be running total of 5cells, I'm running a 1500kv brushless motor and a dynamite 60amp esc would this set up work ok or would I need to modify anything? Thanks.
Depends on the prop you're planning to use.
I was looking at the octura x445 prop.
Okay so that's a 2.5" pitch prop. What's the size of the motor?
It's a kv1500 motor
That's doesn't tell me much. A 1500kv motor can be 20mm diameter or 20omm. I want to know the diameter and depth of the motor.
What boat are you puting it in?????
Is the motor in or outrunner
What make and model is the motor
regards
Alan
It's in a miss geico 29, it sais on the motor dynm3835 1500kv 6-pole.
This one?-
http://www.horizonhobby.com/products/DYNM3835?cm_mmc=BrandSiteReferral-_-PRB-_-ProductPage-_-DYNM3835#t1 (http://www.horizonhobby.com/products/DYNM3835?cm_mmc=BrandSiteReferral-_-PRB-_-ProductPage-_-DYNM3835#t1)
Your motor and batteries are up to it. Little bit concerned about the ESC. If it's a true 60A continuous, then you should be okay. If the spec is optomisitic, you may need a controller with higher rating. Not exactly sure how much current your motor will pull, but would expect somehwere between 20-30A at full tilt. Make sure the watercooling is plumbed in.
Yeah that's the motor I have, my esc is a Dynm 3815. Thanks.
