The Shipyard ( Dry Dock ): Builds & Questions => Working Vessels => Topic started by: sailorboy61 on January 09, 2013, 10:28:53 am
For those builders that go to the length of adding frames around their windows, which obviously greatly improves the appearance, I was wondering just how you go about this.
Thinking about doing it myself, I imagine that I would apply the likes of thin evergreen strip around the inside of the window cut out and then the 'glazing' inside this, however it seems a tricky idea to get it all fitting neatly. For it to appear neat on the inside too, I can't immediately think of an alternative method as glazing simple glued to the inside and framed externally probably wouldn't look right.
What's the best way you've found.
I use a cheap HO or N Gauge rail , The type that comes on the cheap plastic ready to lay out.
Yes It's time consuming but you get a real metal frame . As for the glass I just glue it to the inside walls of the cabin.
Lexan or Vivack, PETG are some of the window stuff you can use thickness varies from .010 to .060 .
Lexan is sun light safe the other will get hard and fail in about 10 years if your tug is in the hard sun everyday .
Some fellows have made individual vacuum forming molds for each window ,This is best if you want the bolted together look .
Lots of the newer modelers just look at this and then paint the windows black in stead.
Opening the windows up really adds to the look , I usually go after the house insides as well .
Spend 2 weeks inside the house in details .
Gary
+1 on using rail to make your window frames.
I used HO guage rail in one of my boats.
I would recommend the base flange to the outside, it's wider.
that looks impressive -- good thinking
Thanks - I have some of that laying around somewhere, will give it a go!
Umi,
As the through section is roughly 'T' shaped, can you please give us a run down, on how you made the 'corners'.
I made mine about 55 years ago from OO guage nickel silver rail.
The corners were bent with round nosed pliers (stretching the memory) but there is a limit to the radius.
Slight kinks can be filed down since there is a slight thickness.
Varnish before inserting glass and installing.
I did the same as Brian, just bent the rails around a needle nose plier.
I don't recall any splitting on the outside bend, but I did have to do a
couple of the frames twice, to get them sized correctly.
I then soldered the joint and pressed them into place.
Umi & Brian,
Thank you, then thats the way to go :-)) :-))
i guess its a case of what scale you would like your window frames...!!
these are at a scale of 1:96
the Window Frames were made out of brass tubeing that what milled down a little to give a wall thinkness of 0.2mm and then cut off so i had a load of rings.
the rings were then drawn over a jig that reshaped the rings from round to rectangle
Very nice tip Colin, Thank you for posting.
The round to rectangle is totally unexpected.
I thought I was looking at round or square tubing sections.
8)
if you know roughly the size of window frame you would like....
for example the above windows are 4 x 6 mm
add all the sides together minus the wall thikness and divide by Pi this will give you the inside of the tube...
4 + 6 + 4 + 6 = 20 (all sides total)
0.2 + 0.2 + 0.2 + 0.2 = 0.8 (wall thinkness total)
20 - 0.8 = 19.2 (minus wall thinkness)
19.2 / 3.14159265 = 6,1115498217122452205889901098413
so your looking for a tube with a inside diameter of about 6mm
Hi Colin.
because I'm into seagoing modern merchant ships too your method of producing window frames with least effort, which is especially applicable to scales from 1:50 to 1:100, is invaluable to me.
Thank you for sharing and also showing how to determine a proper tube diameter,
though I must say that I find a 32-bit significand in your division involving Pi a little bit exaggerated.
Ralph
sorry Ralph,
a agree that it is a little on the large side, i just copied the figure from the computer Calculator.. %% %% %%
You can obtain square and rectangular brass or plastic tube with a thin wall section from https://www.eileensemporium.com and slice off a frame of any depth you require. In the smaller scales from 1/72nd. the frames can then be glazed with liquid products such as Deluxe Materials "Glue'n'Glaze or Microscale "Kristal Klear" which when dry is sealed with gloss varnish. Either work well.
Chris
