The Shipyard ( Dry Dock ): Builds & Questions => BMPRS - British Model Powerboat Racing Society => Topic started by: A66 on January 23, 2013, 09:31:49 pm
Hi Guys, Thought you might like to see new AA boat for this season, still a lot of testing to do, had carb probs so couldnt set pipe length yet, then the pond froze which hasent helped, once we are up and running again will get race numbers on.
looking good m8 ! roll on the better weather !
That'll be 3 x GPL 1000's running this season then, although mines in A class with an ASP 46M on board :} I hear someone will be running one of Grahams tunnel hulls in the new Class 1 as well :-))
Looking forward to our first BMPRS race at Leicester on 24th March O0
Scoop
Evening all, Quick update finally got AA class GPL on the water this morning, carb sorted and pipe length near as it will ever be, Pipe performed really well and sounded really sweet (Thanks Scoop) one problem to sort now Blasted manifold melted! >>:-( but it was certainly shifting!LOL, roll on Leicester!
Steve.
very nice and well built,very impressed :-)) :-)) :-)) kurt black magic racing
Hi Steve
Ha, you think that will beat my "yellow peril"?? Well ok, it may do - but I'll not make it easy for you :-)
Re the exhaust join - if you don't have the tuned pipe sliding over the manifold, the butt joint will blow hot gas out. The best way is to extend the PIPE end with a bit of wider tube so that it slides a bit over the end of the manifold pipe. If this can't be done, put a piece of hard PTFE tube (about 20 mm) over the two ends of the butt joint, then a 40 mm piece of silicon over the two ends.
Or better still, water cool both ends.
Danny
Hi Danny, as you can see from the photos the pipe has come away from the engine side, my fault as i had modified the original wrap round manifold then modified it again for a longer pipe, not alot of aluminium left. have now made it from brass and stainless steel, the pip does indeed slide over this pipe but i have now fitted a water cooling ring as well! I reckon this new boat could be a handfull in choppy water, left stick going to get some use i guess. dont know if you have found any local water to run on, but Graham lay who supplies the GPL lives near Lowerstoft and he has invited Greg and myself up for some racing on their water.
Steve
Excellent bit of repair work there Steve, someone is after yer trophy Danny %)
See you all soon, only 6 weeks to go to the season opener at Leic's. Booking in office will be opening soon, check out www.bmprs.co.uk (http://www.bmprs.co.uk) for details :-))
Scoop
Well I've been away and now I'm back here is a short vid of this being tested.
http://youtu.be/RWQr9S8Uevk (http://youtu.be/RWQr9S8Uevk)
This is the first video I've uploaded to youtubes next time I will use a potato to film as the iPhone 5 doesn't seam much cop {-)
Pretty quick for an AA boat you got there Steve, nice and stable as well. See you soon Cheers
Scoop
Mr scoop were can I get some bmprs stickers from ?
Hi Steve
I reckon that your new boats look the business. I like the fact that these hulls have plenty of freeboard and should be good for choppy water so often seen at BMPRS events.
Craig
Thanks Craig. These hulls are brilliant for the price, very stable still plenty of tuning to do, Choppy water does tend to spin if not quick enough on throttle LOL! May have to wait to use it in anger still struggling to get fit after my op, still hope to catch up with you all soon. :-))
Steve.
Try contacting Danny I think he may have some left :-))
