Technical, Techniques, Hints, and Tips => The "Black Arts!" ( Electrics & Electronics ) => Topic started by: Tralee on May 18, 2007, 09:26:04 pm
Anyone able to tell me wher I may purchase 1mm plug and sockets from I have tried Maplins but to no avail
Tralee,
http://cpc.farnell.com/jsp/home/homepage.jsp has 1mm stackable plugs are these any use? 1mm plugs/sockets seem to be like hens teeth.
Barry M
Thanks for the help Barry but these are not whay I require :-[ :-[
RS has them in a 2 pole config.
http://rswww.com/cgi-bin/bv/rswww/searchBrowseAction.do?D=1mm%20plug&Nr=AND%28avl%3auk%2csearchDiscon_uk%3aN%29&Ntk=I18NAll&Nty=1&Ntt=1mm%20plug&Dx=mode%20matchpartial&Ntx=mode%20matchpartial&N=0&name=SiteStandard&forwardingPage=line&R=0466472&callingPage=/jsp/search/search.jsp&BV_SessionID=@@@@1119619729.1179694795@@@@&BV_EngineID=ccccaddkmjilleicefeceeldgkidhgi.0&cacheID=ukie (http://rswww.com/cgi-bin/bv/rswww/searchBrowseAction.do?D=1mm%20plug&Nr=AND%28avl%3auk%2csearchDiscon_uk%3aN%29&Ntk=I18NAll&Nty=1&Ntt=1mm%20plug&Dx=mode%20matchpartial&Ntx=mode%20matchpartial&N=0&name=SiteStandard&forwardingPage=line&R=0466472&callingPage=/jsp/search/search.jsp&BV_SessionID=@@@@1119619729.1179694795@@@@&BV_EngineID=ccccaddkmjilleicefeceeldgkidhgi.0&cacheID=ukie)
If not, what about using Futaba pins and sockets, with or without holders?
Danny
It is still permissible to make your own - 1mm brass wire for the male, 1mm I/D brass or copper tube for the female, solder the wire on and insulate as required with shrinkdown. to provide a tight fit, the tube can either be GENTLY squeezed, or split and squeezed, or the male part given a slight bow.
