Technical, Techniques, Hints, and Tips => Batteries & Chargers => Topic started by: 2051476 on April 03, 2013, 06:15:53 pm
This is a just make sure question. I have two sealed acid gel battery's and was wondering if I could lay them on their side in the hull I.E. Lower center of gravity
No problem
The only thing to realise is that SLAs are lighter at the top
Therefore think about the balance when they are laid down.
As Netleyned says no problem, if they are difficult to remove/fit lying flat
do as I do glue a ribbon/webbing finger loop to the battery
or tie a piece of string around them so that they can be removed easily.
better than pulling them out by the connection wires.
john
Thanks for the answers
john
Good idea, O0 O0 O0 :-)) :-)) :-))
No problem
well ill be blown
now i know way my TC listed to one side ,as i laid the L/A batt on it side AND couldn't figure out way it listed never thought about the batt being lighter at the top
cheers
