Technical, Techniques, Hints, and Tips => Painting, Finishing and Care. => Topic started by: dmw_boatboy on April 21, 2013, 03:37:50 pm
Afternoon all :-)
I have a Mobile Marine Models Grp hull which i am getting near to painting and would like a bit of advise regarding what sort of prep and paint to use as i normaly scratch built from wood.
I Normally use a cellulose paint for my models but im not sure if its ok to use on this sort of hull.
And advise and tips i would be thankfull :D
It will be fine. Rub it down well with wet and dry so the paint has a good tooth.
Brilliant thank you ill make the most of the sunny-ish weather and get going.
Read MY guide in the painting section
Thanks for pointing that out very interesting read and very helpfull :-))
Its amazing how when you look for somthing you never find it if its right there infront of you :embarrassed:
