The Shipyard ( Dry Dock ): Builds & Questions => Seaport Tugs => Topic started by: tugboattam on May 08, 2013, 09:02:11 am
Hi all, Is there any particular slot in the reciever that the lead from the ESC should be plugged into or does it not matter ? Ian.
Pin 2 on 2 channel set 3 on 4channel this is usually the case
Normally marked Throttle
Usually pin set 2 or 3
Hi Ian.
I will assume you are using a 2channel set for the seaport refurb. Below the sticks on the transmitter they are numbered
(1) right hand stick (2) left hand stick. You will note the right hand stick (1) moves left -right this is the stick for the rudder and corresponds to hole no1 on the receiver for the rudder servo. The left hand stick (2) moves forward-reverse this is the stick for the speed controller and corresponds to hole no (2) on the receiver.
There is also a slider switch next to each stick this is a trim switch and is used to centre the the speed controller or the servo arm on the rudder servo.
frank.
Thanks for the replies, thats another problem sorted but Im sure there will be more !! Ian.
