The Shipyard ( Dry Dock ): Builds & Questions => Seaport Tugs => Topic started by: lakesidebob on May 12, 2013, 10:42:05 pm
Hi All,
I'm new to the Forum and newish to boats,last had a Graupner Patrol Boat in the 80's and promised i would return one day.Now retired.
Have just tried my Workboat yesterday after converting it,big help from you all on the Forum,thankyou, and am delighted with it.I feel the motor/prop shaft is a bit noisy,rattles and wondering if changing the drive shaft coupling and greasing the shaft would make it quieter,but not sure how to get that lot out.Have introduced some oil into it by the propeller and will try it again soon.Any help much appreciated,many thanks..Bob.
Hi there just read your post im working on a sea port at the mo i would change the joint use a dremel to split the joint on the prop shaft end and the motor part just slides off. The motor shaft is an eighth and the prop shaft is an m4 type you will need two brass couplings and connect them with a piece of rubber petrol pipe see my downloaded pics note you will need the brass drives with the small grub alan key fitting hope this is of help best regards.
Hi Tug
Many thanks for your reply to my rattling Workboat coupling query.I have found your Tug Pix and the coupling picture,looks as if that should do the job.Where's me Dremel?.Many Thanks again.Bob.
