The Shipyard ( Dry Dock ): Builds & Questions => Yachts and Sail => Topic started by: jcarse on April 09, 2006, 12:13:18 pm
I'm nearing completion on a Tony Able design of IOM, I notice from reading through the rules that a Deck Limitation Mark is required.? Can anyone tell me what this is and where it should go?? :-\?
To quote from the IOM rules:-
"The deck limit mark shall be displayed on the centreplane of the hull near to the mast position. It shall be a minimum of 5mm in diameter"
Basically it is a round black mark on the centreline of the deck close to the mast. It is used as the deck reference point when measuring the rig.
Alan
Thanks Alan, Just wish the rules would say that!!
Many thanks for your help
I know the topic has been dead for a while, but I am also on the point of getting my 1OM measured and casting around for a suitable 'spot' mark, I tried using a paper - hole puncher on fablon and hey presto, a nice sticky back spot a gnats whisker over the minimum 5mm dia. One word of warning -? carefully empty the hundreds of previous paper spots first otherwise she who shall be obeyed will not be too chuffed with the confetti !!
MikeK
Thanks for that Info...............will give it a try!!
;D
