Technical, Techniques, Hints, and Tips => BRUSHLESS Motors and Speed Controllers => Topic started by: bubbletop409 on November 29, 2013, 05:56:28 pm
Hello Crew
I am new to brushless and currently setting up a 1/16 Air Sea Rescue boat with dual brushless motors. My question regards programing the ESC's, when programing duals do you do each one separately or do you leave the "Y" connector connected and do both at the same time? Thanks for the help.
Larry
Hi Larry, when I set my esc,s up I did them separately then removed the
red lead out of 1 speed controller rx lead, you will need to do this if you
are using the esc, BEC circuit I used a program card when I did mine.
I run mine on Left & right stick so no need for mixers or Y leads.
john
Hey John
Thanks for the reply, I'll do my programing the same way, and I did know about removing the positive lead from one bec circuit.
Larry
