The Shipyard ( Dry Dock ): Builds & Questions => Working Vessels => Topic started by: grace on March 01, 2014, 08:50:33 pm
do you need steerable kort nozzles if your running twin motor with a pair of esc??
No as you can buy a ACTion mixer to allow you to steer off the right hand stick on th e controller,what this will do is to reduce power on one motor and increase the other one thus allowing you to steer
You never need a steerable Kort, they just give a bit more steerability than most simple rudder solutions.
For twin props being able to control each shaft independently gives good manoeuverability - a mixer will sometimes be enough but completely separate control (aka 'tank' steering) is best - it's what full size boats use. The downside is it needs two r/c channels for power control, although with modern 2.4GHz systems that really isn't much of an issue.
(Does anyone actually use steerable Korts on twin prop boats (in the prototype)?)
my pusher tug uses steerable twin korts when i got it. it was on one esc but iv converted it to two esc's..most of the time i use the throttles like tank tracks to maneuver, if im doing really slow work i use the korts to steer but mainly the throttles.....the next tug i get i want to make it very powerfull with twin screw,,,,,is there any benifit in using a tube over the props and then a normal rudder??the boat will have a bow thruster at the bows.........
grace....I do not use any form of Kort nozzle, however remember reading many years ago..... %) during the development of the said system, tests on propeller performance were confirmed as having greater thrust [with the water being directed through a fixed tube], than open water for the same input power............
I am sure a search on WIKI will find some references back to these [1960's?] studies.................Derek
I have a pusher tug which is used as a rescue vessel at our club lake. It has 2 motors and ESCs, and is steered by tank steering. It has no Korts, but a smaller version I built for my grandsons in Sydney has a single, non-steerable Kort. It has great pushing power for its size, and I think that's down to the fact that it has the Kort nozzle.
Peter.
A little piece of semi useless information {-)
Between 1976 & 1979, Australia commissioned the building of four 100,000 DWT bulk carriers in Norway
Being named the 'Australian Pioneer, Purpose, Prospector & Progress'....naturally they were termed as our P boats.........suffice to say....on completion each could not secure a cargo & each spent many months at anchor in the fjords of Norway
I do remember flying 3800 km from Sydney to Perth to Dampier to inspect a fault with the Prospectors main engine Woodward governor hydraulic amplifier >>:-(
Cut a long story short :embarrassed: each of the P boats was fitted with a FIXED kort nozzle........... Derek
In the prototype a Kort is not just a tube - it's a carefully shaped hydrodynamic article matched to shaped propellers which increases the efficiency/thrust. When they are made steerable there is almost certainly a trade off of some efficiency as the clearances/shapes will need to allow for rotation. So although not uncommon on single prop vessels I wonder if it would be done on twins in the prototype, which have better manoeuverability anyway.
I realise the full size Kort is hydrodynamically shaped, but I didn't bother with mine, just using a piece of 50mm PVC tube. I did, however, shape the tips of the prop in a lathe, to give less separation between prop and Kort tube. I placed the rudder directly behind the Kort tube, and this gives extremely responsive steering.
Peter.
