The Shipyard ( Dry Dock ): Builds & Questions => Navy - Military - Battleships: => Topic started by: Stan on March 19, 2014, 08:05:15 pm
Hi Guys. Just finished rewiring my D U K W what a job parts to remove then glue back in re solder the basic wheel axles also. Next job repaint parts re varnish good for the next 5 years or more.. :(( :(( :(( :(( :(( :-)) :-)) :-)) :-)) :-)) :-))
Stan
Aint it fun getting at all the fittings in awkward places !! Not to mention tidying up spaghetti wiring .
Malcolm NZ
Checked all wiring connections this evening all working fine. Paint work touched up and ready for the varnish coat tomorrow. :-)) :-)) :-))
Hi Stan
Thank you for posting your DUKW and giving me the spark of interest again. Would you mind answering a few questions?
Here I go, what scale is it? Where did you get the running parts for it? What did you use for suspension? Does it also go into the water ?
Thanks For your Help/Information.
George
Hi George thank you for your interest in my DUKW. You have asked if I could supply plans for this model. Sadly the answer is no I built my model using pictures taken at Duxford and the tank museum at Beverley. Sorry I can not help more. :(( :(( :(( :(( :(( :((but if you need any information at all please PM me :-)) :-)) :-)) :-)) :-)) :-))
Stan
Deans Marine do a 1/10th scale semi-kit of a DUKW (my example was of an appallingly low standard and the hull took a lot of work to sort out). Running gear/suspension was obtained from a German company but were very expensive. http://www.mts-boenning.de/index.php?inc=inc_produkte&kategorie=D.U.K.W.&menu=menu_katalog (http://www.mts-boenning.de/index.php?inc=inc_produkte&kategorie=D.U.K.W.&menu=menu_katalog)
