Technical, Techniques, Hints, and Tips => DC Motors (Brushed) and Speed Controllers => Topic started by: type82 on May 17, 2014, 08:22:46 pm
I am after a motor for the above tug that has a 70mm 4 blade prop and a 12v 7amp battery what do you suggest thanks
A 900 type motor would do the job very well.
Ken
This one will be spot on and direct drive as well..
http://modelboatbits.com/shop/article_MBB-900M/900-HIGH-TORQUE-MOTOR.html?sessid=lyaBOQXcFn7Da3GB48wMnEyvviuxQEfAfC2Xqekr7NO328HS4zOvXFnv3bQf3iNR&shop_param=cid%3D86%26aid%3DMBB-900M%26
Paul..
I use Mobile Marine Models T12. I have had them in 3 boats now, all tugs around 40-48 inches. Lots of torque and I get about 90 mins out of a 12v/7AHr Batt as long as I don't hammer it.
900 motor all the way and not Amp hungry neither
Hi, Mine is fitted with an MFA, Como drills 919D and 6:1 gearbox. Seems to work fine. :-)) Graham
