The Shipyard ( Dry Dock ): Builds & Questions => Seaport Tugs => Topic started by: rhardy67 on June 07, 2014, 05:36:58 pm
Just changed out the toy electronics to hobby grade and i like how it turn out , put in a HOBBYWING QUICRUN WP1625 R/C Fwd & Rev W/BEC Brushed 100A ESC and Nx Metal Gear Digital 13kg Servo MG946 High Torque and using a FLYSKY Transmitter FS-GT2B 2.4Ghz radio system , stayed with stuck motor and using Traxxas powercell 5000 Manh nimh 8c battery . Hears a short video of it on water for the first time after upgrades http://youtu.be/NKHOni8Qvlo (http://youtu.be/NKHOni8Qvlo)
This is a still work in progress .(http://i1099.photobucket.com/albums/g400/rhardy60/2014-06-01203651_zpsd36706df.jpg)(http://i1099.photobucket.com/albums/g400/rhardy60/2014-06-01202145_zpsea1f4843.jpg)
Hello there rhardy67 and welcome to mayhem you seem to be getting on with that mod i would advise to remove the ballast tank and isopon the inlets closed hope all goes well best regards. tugboat pete YAAAARG
Thought about removing the ballast tank but that where the battery sits on . if i would remove it how much weight would i have to add ?
yes i understand but if you cut out the ballast tank use isopon p36 to fill the inlet slots you will be able to fit a battery lower into the hull im posting my ballast weights position you may find that you wont have to use so much taking into account the battery weight have a look at my posts on this mod hope all goes well good luck and keep on pulling YAAAARG.
The battery i use is a traxxas 8c 5000 mah nimh battery and is alot longer than what your use . mind sets on top of the ballast tray between the 2 blue strips of rc wheel weight .
Changed video . hear it is before an after upgrades .
http://youtu.be/5Ua4nmFsOBE (http://youtu.be/5Ua4nmFsOBE)
