Mess Deck: General Section => Chit-Chat => Topic started by: regiment on September 27, 2014, 01:09:52 pm
trouble with my montronic esc red and green lights not flashing (no jokes) only red light comes on motor not turning rudder ok new tx rt sent it for check came back this morning invoice saying all checked and working put it back into boat guess what up no green only red staying on so will be sending it back for recycling on Monday unless some one knows better
Give Mtroniks a call, they will help you out over the phone, tell you what to do. They are very good like that.
hi u33 just got it back from montroniks £5 for nothing said all ok
What tx rx are you using Gordon?
Is the esc a plug and play or does it have
asetup button?
hi 27 mh plug and play tried every thing except the hammer
Just switch the Tx on first make sure the throttle is central.
Switch on the esc and receiver and move the throttle
slowly forward.
You should then get a green.
If you get a red then you must reverse the Tx setting for
the throttle.
Does it work now?
Gordon , If you have a solid red led on the ESC it means no signal
from the RX.
If as you say the rudder servo is working, then double check the
esc lead is in the right socket on the RX.
Common mistake made by most of us at sometime is to push
the esc connector plug alongside the pins on the Rx so no connection.
hi after walking half a mile to my friends house with the boat etc I let him have a go looks like the hobby receiver is playing up put one of his in boat all ok so looks like more exspence think I will go back to paper gliders cheaper
thanks for all your help gordon
27mhz rx in the post to you when I get home Monday :-))
hi thanks very much for your kind offer will put a few bob in local rnli box gordon
