Sales, Wants & TRADERS => Whats in the box? => Topic started by: Mike0001 on November 17, 2014, 06:35:12 pm
(http://i156.photobucket.com/albums/t6/mike070868/PICT0118_zpsa486b813.jpg) (http://s156.photobucket.com/user/mike070868/media/PICT0118_zpsa486b813.jpg.html)
so I got these at the show, plan and guide are for styrene model so not really suitable
transom ? is this to be doubled up there are 2 which I think are the transom ? if you look at parts on top of keel
I would have said so O0
thanks
also the hull frames which go onto keel,
they are different but none match up to plan size wise ? how do you tell front and rear ?
anyone help me out there
Thats good timing, ordered one of those last night and they rang this morning to ask if i also wanted the plans, said yes but did'nt know they were for styrene, never mind. Is this link any good to you, i know the frames look a similar size but it might help
http://www.modelboatmayhem.co.uk/forum/index.php?topic=44202.0 (http://www.modelboatmayhem.co.uk/forum/index.php?topic=44202.0)
regards Jack.
hi
when you get yours, you may have same problem as me, there is a little difference in them and plans do not help as you will find out
one looks to have longer cut width to it which going by the link I think goes at rear, or as I have it in pic
Hi, yes you're right i probably will have trouble, what about the notches on the frames do they line up in the deck, just had a look at the video on their website it's hard to tell accuratley but possibly the wide one goes to the front. Very little info on the www about them http://gb.trapletshop.com/pilot-boat-laser-cut-wood-pack (http://gb.trapletshop.com/pilot-boat-laser-cut-wood-pack) <:(
regards Jack.
might have to email traplet and ask.
this is the starting point and if we get this wrong it will be a world of hurt
edit sent traplet an email :-))
Thats true and if anyone can get it wrong i will, let me know how you get on
regards Jack,
Just double-checked my partly built model and plans - the rear bulkhead is slightly higher, and the front bulkhead has a more pronounced v. Makes sense to me, because the bottom pieces are starting to twist and curve up towards the bow in the vicinity of the front bulkhead.
I received an extra transom, all 4 pieces for an extra boat stand, and extra fronts and sides for the 'radio box'. Better too many parts than too few! :}
Tom
Hi Mike,
I'm tagging along to see how you get on with the kit.
I built the styrene version from the free plan (which had some errors on it, which I put down to the reproduction for the magazine)
Mine's here http://www.modelboatmayhem.co.uk/forum/index.php/topic,47660.msg483402.html#msg483402 (http://www.modelboatmayhem.co.uk/forum/index.php/topic,47660.msg483402.html#msg483402)
